1/4 mile help
Old Apr 20, 2014 | 12:34 PM
BurnsyEP3's Avatar
Default 1/4 mile help
hey so i've got a stock k20a3 ep3 with a magnaflow catback and a SRI, the best i could get on the quarter was 16 flat, that was running 225s all around, this time ill be running skinnys in the rear and 225s in the front, I'm gutting the car down to a drivers seat but need more hints on tips to drop my time as all my buddies are in low 15's or 14's and I want to be a little competitive but I'm in a budget and the race is in a few weeks. I know how to drive the car and am consistent with my shifts and everything along those lines, so anything else would be greatly appreciated.
Old Apr 21, 2014 | 06:26 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: 1/4 mile help
Post up time slips. What tire was on the car, need more info than just the width.
honestly, what more do you expect from this car?
I'm sure your buddies are making more power too then.
Old Apr 21, 2014 | 07:51 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Well honestly... practicing and experience are the best. Your 60ft is on of the most important things to work on... get a good 60ft get a good 1/4 mile
Old Apr 21, 2014 | 08:13 AM
Mattb16teg's Avatar
Community Builder
true however there is only so much you can do with like a 140 whp car.
Old Apr 23, 2014 | 07:35 PM
turbohatchBnuts's Avatar
Have you seen this? Might help.
http://www.importtuner.com/features/...i/viewall.html
Old Apr 24, 2014 | 06:25 AM
mustclime's Avatar
motor mounts.....good front shocks....they cut down on wheel hop.
Old Apr 24, 2014 | 05:44 PM
BurnsyEP3's Avatar
Originally Posted by turbohatchBnuts
Never saw that before but thanks man
Old Apr 25, 2014 | 04:40 AM
Mattb16teg's Avatar
Community Builder
Will not help and will make your car a loud crappy tin can, see my first post to start getting help.......
Old Apr 25, 2014 | 04:59 AM
doitpropa's Avatar
i dont understand how stripping a car will not help don't listen to this guy cut that **** to pieces
Old Apr 25, 2014 | 05:32 AM
Mattb16teg's Avatar
Community Builder
LoL yea, go right ahead......
In a car that has no power and isn't a dedicated track car, it makes 0 sense to do this.
That is a drastic suggestion and would only help knock very minimal time, nothing worth the effort and destroying the car.
Old Apr 25, 2014 | 05:41 AM
doitpropa's Avatar
idk got a 15.2 out of a bone stock junkyard swapped d16z6 integra on street tires has 14s once i fix the wheel hop just weight reduction
Old Apr 25, 2014 | 05:50 AM
Mattb16teg's Avatar
Community Builder
15.20s with bench racing 14 second times, can't argue with that!!
OP, I'm here to assist if you really want good, helpful advice......
Old Apr 25, 2014 | 05:58 AM
doitpropa's Avatar
yea cheapest easiest way to go fast is weight reduction nd slicks
Old Apr 25, 2014 | 06:00 AM
doitpropa's Avatar
one of the best things is also a good alignment
Old Apr 25, 2014 | 06:09 AM
Mattb16teg's Avatar
Community Builder
I would just reword that to say "go faster".
Yup! Will pick up MPH even on the slowest of cars. Most people forget about alignments. It's sad.
Old Apr 25, 2014 | 06:16 AM
doitpropa's Avatar
to the op find a header when u get to track remove accessory belts if u can .. I'm not sure how those are set up ima b series guy air up your rear tires to max .. or a little past lol less rolling resistance r you burning out ? if not drive around the water box if u have a second set of tires for front that are snows u mite b able to try them they are normally a softer compound
Old Apr 25, 2014 | 06:30 AM
Mattb16teg's Avatar
Community Builder
K series use 1 belt and an auto tensioner.
A header and FlashPro(and a tune) would be perfect to help pick up some power in this. A good radial or slick as well.
Burnouts are not worth it on most street tires too, so if you are on one, avoid the wet box.
Old Apr 25, 2014 | 07:34 AM
doitpropa's Avatar
if u can take out a headlight and make a v stack
Old Apr 25, 2014 | 07:41 PM
rs2000x's Avatar
race gas maybe? the main problem is the low comp ration in the a3 motor,
supercharger is a cheaper way to fix that with out using nos
Old Apr 26, 2014 | 08:39 AM
BurnsyEP3's Avatar
225/45/16 BF Goodrich GForce sport T/A street tires
time slips I don't seem to have any kicking around but I know I was running about an 83 MPH trap speed as I can recall. Depending on if my clutch and engine holds up this year I will be headed back out to the strip fairly often
Old May 1, 2014 | 11:09 AM
Mattb16teg's Avatar
Community Builder
Well that is about as much as you can expect with that MPH and MPH doesn't lie. I would guess it was like a 2.4 60 foot as well?
Lowers ETs in this situation would be due to a better 60 foot time among other things.
Flexmyrex
Mar 18, 2005 08:48 PM
*Boostwerks*
Mar 15, 2005 09:08 PM
93LSivic
Dec 3, 2004 05:45 PM
PerfectXtreme
Sep 9, 2003 10:12 PM
