What ECU do I need?
Old Oct 29, 2002 | 11:22 PM
Dj Lotte's Avatar
Default What ECU do I need?
Ok I just bought a car (1991 CRX Si~$1,000) that was stolen after it had blown the engine (pantyhose for an air filter) and now I have the car and it has a 1.6L SOHC VTEC motor from a 1992 Civic Si. The distributor doesn't completely bolt on, and it doesn't have the right ECU apparently, because the cables don't reach the VTEC pice in the head. The shop, ImspoRt Racing, told me I need a new ECU, but I dunno which ECU I'd need....so I'm coming to you guyz for help. Which ECU is the right one for the car???
Thanks,
Mike Thomas
Old Oct 29, 2002 | 11:33 PM
eur0's Avatar
Default Re: What ECU do I need? (RiceFx306)
p28
Old Oct 30, 2002 | 04:10 AM
USDM 4G VTEC's Avatar
if the car it still wired as a OBDO i say get a Zdyne ECU
if it has been converted into OBDI then get a P28
Old Oct 30, 2002 | 12:07 PM
cbrman's Avatar
Look on the drivers side wheel well for the injector resistor box. If you see the injector resistor box, then you know it is still wired for obd0. I suspect someone modified an a6 distributor and put it on there. If that is the case you would need an obd0 ecu. I have heard integra ecus would work, or you can use a pm6 ecu from a crx.
If you decide to upgrade to obd1 then like everyone else said use a p28 ecu.
Old Oct 30, 2002 | 12:19 PM
Rob!'s Avatar
Default Re: What ECU do I need? (cbrman)
p28 yes sir
Old Nov 12, 2002 | 11:04 PM
Dj Lotte's Avatar
Oh I got more information...I have a motor out of a 1992 Civic Si hatchback motor in a 1991 CRX Si. I've heard that even the Si's didn't have VTEC so the ECU I have won't work properly, since no CRXs in '91 had VTEC. So the guy said he can make it run w/ the current ECU, I dunno. though..I'm thinking I'm going to be in the market for an ECU. You guys are 100% sure about that ECU? I don't wanna blow it on some gay shyt.
Old Nov 13, 2002 | 03:20 PM
Noahk's Avatar
The P28 is the right ECU for a 92-95 d16z6 but it will NOT plug into your stock harness unless it is modified. If your distributor doesn't fit right they are using the 88-91 OBD0 electronics to run the car. The conversion to run the P28 takes some work and money(you need the correct distributor, injectors, and ECU). The best option is the zdyne one wire conversion. As the name suggests it's just one wire and will make the car run the best.
http://www.zdyne.com/convhome.html
"Perfect for B16A VTEC engine swaps or D16Z6* / D16Y8** VTEC head swaps
*The 88-91 Si/HF distributor is required. **88-91 Si/HF distributor bolts right on! "
Old Nov 13, 2002 | 03:44 PM
pdiddyparsons's Avatar
p28!!!!!!!!! for that motor but,if u have an old si, it probablyan si ecu w/ a si wireharness and no vtec and si distributor
EKiddd
Jul 29, 2013 11:16 AM
WesL
10
Feb 13, 2009 05:39 PM
memorybox
Nov 28, 2006 07:58 PM
EnSAn
Jul 19, 2006 02:27 AM
trustnoone7935
Nov 24, 2004 08:34 PM
