Help D15b
Help D15b
I need help on my 95 civic DX hatchback. I have had this car awhile and i need some info on it. All i know is that it has a D15b vtec engine with a P08-3 head on it. The ecu is a P06 and the distributor is a td-41u. I am thinking that it has the wrong ecu and distributor. i know the distributor is wrong because the brackets holes on the distributor are cut to make it fit. The car runs ok besides the fact it surges when you first start it up.
Re: Help D15b
its a werid vtech-e ecu but i have the same swap in my DX you can use a regular SOHC vtech dizzy but u need the p07 ecu u can even use the d16z6 dizzy if you got one laying around or chip a p28 its up to you
Re: Help D15b
yea i was going to say that i thought the p07 was for the vtec e. i was thinking that the p08 was the one i needed. because the civic vx is a d15z1 motor i thought.
Re: Help D15b
Ok im almost sure that the engine is a jdm model d15b. according to wikipedia because it has the p08 head. so i should put a td-42u distributor and a p28 ecu in it right.
fast90hatch
33
11-30-2004 09:23 PM
