replacing heater hoses.
Old Apr 20, 2014 | 06:30 AM
crazyhouse2011's Avatar
Default replacing heater hoses.
1995 Civic EX 5MT
I'm in the process of replacing all the radiator hoses in my engine, including the heater hoses and the little 3/8 hoses. The little short S-bend hose that goes from the heater control valve into the firewall (sitting behind the HCV) seems like it's gonna be a bitch to get out. Should I just remove the HCV and replace that hose? Or do I need to? And if so, could someone please give me tips or precautions because i have spent days looking for youtube videos and forums on this subject and have come up mostly empty handed. I already know the HCV ports crush easily. I just am unsure how I unhook the HCV.
Old Apr 20, 2014 | 07:12 AM
Default Re: replacing heater hoses.
bump!!!
Old Apr 20, 2014 | 08:36 AM
edwinie26's Avatar
BEWARE OF YOUR HEATER CORE!! i bent mine in a swap and caused engine to overheat!
all the coolant would shoot out when it built up pressure.
my solution after this: bypass... so no more heater
Old Apr 20, 2014 | 08:43 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If you are replacing the hoses, you can always cut the old ones off so as to not risk collapse of the metal tubing. A sharp razor will glide through the rubber pretty easily without a lot of pressure.
Then to put the new hoses on, you can wet the hose with water and it should slide onto the metal tubing easier than dry and the water will evaporate cleanly.
Old Apr 20, 2014 | 09:39 AM
I meant like unbolting the heater control valve, is there any precautions? Like the cable, will i have to readjust it?
Old Apr 20, 2014 | 11:24 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If I recall correctly, there is an adjustment that needs to be made if you unhook the flow valve cable.
I'll dig up the page in a bit.
Old Apr 24, 2014 | 05:59 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Busy with work and forgot about this. Here ya go:
Psycho719
Oct 30, 2011 01:51 AM
TooManyTickets
Apr 15, 2008 06:56 AM
spaceman
May 6, 2004 06:39 AM
