B18c1 trouble after rewire
Old Apr 19, 2014 | 05:52 PM
Eghatchy92's Avatar
Default B18c1 trouble after rewire
Ok I'm now lost with this car and I really need some help. It's kinda long so I'll just start from the begining. Quick backround. It's a gsr obd2 to 1 95 civic hatch all stock except for header back, pro series intake, and chipped ECU. My car was running good but threw a cyp. Drove fine just not a lot of power and vtec was ok. I blew my main battery fuse. Put it back on and my car idles good but hit the gas and it sounds like it's trying to 2 step and missing bad. I redid the WHOLE harness to find a short. Nothing that raised a eyebrow. I changed the ECU and re chipped it. Started up and ran great! Went up the road to crack vtec. At the cross over my rpm gauge started shorting out and it bogged and missing then I tried to keep it alive but died. When it died it sounded like I lost compression slowly and it was Hearing it threw my intake. Now my cels are No more cyp but my map sensor my ELD system and my vtec solenoid are throwing a code. Any help will be great!!! Thanks yall
Old Apr 19, 2014 | 06:37 PM
Muckman's Avatar
Moderator in Chief
Default Re: B18c1 trouble
Sounds like a possible short in the wiring. Check your fuses.
Old Apr 19, 2014 | 06:43 PM
Eghatchy92's Avatar
Default Re: B18c1 trouble after rewire
All fuses are good in the engine bay and under the dash
SoLo26
Honda S2000
11
Sep 19, 2012 07:38 AM
CRVTECSCREAMER
Mar 17, 2010 10:30 PM
civic89si666
Dec 23, 2009 06:16 PM
92EG8
Jun 22, 2007 02:47 PM
slo97coupe
Feb 11, 2007 03:00 PM
