Step block or o-ring sleeve block
Old Apr 18, 2014 | 10:52 PM
eg:R's Avatar
Default Step block or o-ring sleeve block
I have a gsr sleeve block and was thinking about stepping the block or o-ring. Which should I do or both would be better. Looking for 500hp+ goal. I was leaning more on just stepping
The block.
Old Apr 18, 2014 | 11:13 PM
Runnerdown's Avatar
Default Re: Step block or o-ring sleeve block
I think you will get a lot of different opinions on this topic. I have used flat decks with no o-ring to well over 900whp without issue. Finish of the sealing surfaces, prep work and installation has been the key to avoiding problems there. The devil is in the details.
Old Apr 19, 2014 | 08:56 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Stepping tends to have sealing issues on the outside and O-rings can cause issues if not installed properly. For your moderate goals you don't need either. As was stated before, shoot for a perfect properly prepped block and head and you will be fine.
10SecDSM
Sep 15, 2006 08:11 AM
preludesi93-arg
Jun 19, 2005 06:44 AM
Soon_2b_evil
Aug 8, 2003 06:40 PM
