automatic shifter cable thing under car, whats proper removal protocal?
Old Apr 18, 2014 | 06:47 AM
PrettyMuchBoned's Avatar
Default automatic shifter cable thing under car, whats proper removal protocal?
93 EH9. There's a cable from where the shifter sits, to the transmission. Its in the way of taking my subframe out. Its bolted to the subframe, and bolted to the car, and finally attached to the transmission.
should I unbolt it from the car near the shifter? Would that be all I have to do? Or is there something inside of it that will still be connected?
http://s1372.photobucket.com/user/fa...090b5.jpg.html
Old Apr 18, 2014 | 07:03 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: automatic shifter cable thing under car, whats proper removal protocal?
In the FAQs, first or second link of engine removal. Way to search.
Old Apr 18, 2014 | 07:37 AM
remove the Honda Civic engine with manual transmission
there is absolutely nothing about automatic cable thing in that article
Old Apr 18, 2014 | 08:01 AM
doctorake's Avatar
Community Builder
You were unclear on your car info, I could not tell it was an automatic transmission.
Old Apr 18, 2014 | 12:42 PM
eghatch9295's Avatar
Stancetard Hate Monger
there is a cover where the cable goes into the trans. remove it. there are 2 10mm bolts holding that cable on, remove them. you can then slide the cable out and you should be good to go.
Old Apr 18, 2014 | 01:14 PM
okay ill be checking that in a half hr when I get home. That and the power steering hoses is all that I need to take out, then I can pull the subframe out and sand off the rust paint it and rebuild my front suspension when my control arms get here
Old Apr 18, 2014 | 02:59 PM
I cant get that rubber cover off, I pulled on it as hard as I could, then tried with pliers and its lodged in there pretty good.
I'm gonna try to pry it off with a screw driver or something
Old Apr 18, 2014 | 09:46 PM
pics?
Old Apr 18, 2014 | 09:58 PM
pics?
http://s1372.photobucket.com/user/fa...9434e.jpg.html
this is a picture of the thing connected to the trans
Old Apr 18, 2014 | 11:43 PM
see where it goes into the trans? there is a plate around it held in by 3 (iirc) 10 mm bolts. remove them. youll see the end of the cable attached to the shift mechanism. the cable is held to it with 2 10mm bolts. remove them, and it will slide out.
Old Apr 19, 2014 | 08:44 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Old Apr 19, 2014 | 11:24 AM
This makes sense to me now. I thought I was suppose to be taking off something else..
thanks alot guys this is the only thing I have left, just took off the power steering hoses. I spent a half hour trying to pull off the larger hose before I gave up and cut it
Mishako129
Sep 6, 2012 03:14 PM
redm3turbo
Jul 31, 2011 10:39 AM
Kasta_JayDeeEm
Jul 7, 2011 06:48 PM
aznevanchoi
Feb 22, 2007 05:23 PM
street95civic
Jul 16, 2005 04:28 PM
