FS: VA Greddy IC, Tial WG, Precision Turbo, Blitz, Moates, BMC Manifold, etc
Old Apr 17, 2014 | 02:55 PM
blufke's Avatar
Default FS: VA Greddy IC, Tial WG, Precision Turbo, Blitz, Moates, BMC Manifold, etc
I've been out of the Honda game for a while, but still have a number of parts for sale. Everything is OBO. Located in Cambridge, MA.
B-Series BMC Log Manifold, Tial 38mm WG, Precision SC34 (0.63 A/R) turbo. All parts have under 10K. I opened up the Tial WG to check the spring (Big Blue/1BAR) and see that at some point previously the diaphragm was pinched down a bit. Does not look like it effects the range of motion (top to bottom) of the diaphragm at all. The Tial is also missing one of the 6 bolts that holds the lid down. Oil near the drain on the turbo is just from a leak at the drain connection. Manifold - $200, Tial 38mm WG $115, Turbo $400, $675 for it all!
Precision/Delphi 880cc Low Impedance Injectors - $175
Blitz Dual SBC Spec-R Boost Controller - $250 (OLD SCHOOL!!!)
Greddy Type 31 with Greddy Type S BOV attached. Bent fins/dent visible on the bottom but it holds boost just fine. The Type S adjustment screw should be retapped, or replace the top of the BOV. Has mounts welded on for EG chassis (was on my 93 GSR hatch previously) - $300
Drag Intercooler. Good shape. Core is 22" long and 2.25" thick. From end to end it is a total of 30" long. 2" inlet, 2.25" outlet. $150.
Autometer Nexus EGT Gauge - $150, ($225 new) brand new in box
Moates Ostrich - SOLD!
BigTeggie Crankshaft Holder - $BEER or Buy something else with it
OBD1 to OBD1 Tuning Harness - $75
Resistor Pack - $20
ECU Eprom Burner - SOLD!
Action Clutch Kevlar Disc for B-series Trannies (came off my gsr). Used under 10k miles. Came from 2KS kit. Engagement is buttery smooth - $100
Marshall Liquid Filled Fuel Pressure Gauge - $20
GM 3 Bar Map sensor - $40
Greddy Catch Can (needs hoses and level hose) - SOLD!
Old Apr 18, 2014 | 06:27 AM
blufke's Avatar
Default Re: FS: VA Greddy IC, Tial WG, Precision Turbo, Blitz, Moates, BMC Manifold, etc
Added BNIB Autometer Nexus EGT Gauge, if someone is interested, I can remove my Autometer Nexus Boost and Oil Pressure Gauges and controller from my STI to complete a full kit.
Old Apr 18, 2014 | 06:41 AM
lsturbohatch10's Avatar
do you have the ribbon cable with the ostrich? jw since its not in the picture.
Old Apr 18, 2014 | 06:50 AM
blufke's Avatar
I do, just added the photo, but it has some badly bent pins. They likely could be straightened out, but I can't guarantee they won't be too brittle. Would recommend a new one from here just to be safe: http://www.xenocron.com/ostrich-emul...ble-p-152.html. But it might be just fine.
Old Apr 19, 2014 | 08:33 AM
blufke's Avatar
Moates Ostrich Sold. Updated the Manifold/WG/Turbo description after checking the spring size inside the Tial.
Old May 7, 2014 | 12:54 PM
G2TegGuy's Avatar
Is the Burn 1 still available? I need one asap!!
Old May 7, 2014 | 04:04 PM
blufke's Avatar
You have PM.
Old May 12, 2014 | 09:09 PM
Charlie Moua's Avatar
still got the clutch? for hydro b series?
Old May 13, 2014 | 05:58 AM
blufke's Avatar
You have PM.
Old May 15, 2014 | 04:52 AM
blufke's Avatar
Burn1 Sold! Make me some good offers!
Old May 22, 2014 | 06:02 PM
blufke's Avatar
Let's get this stuff sold!
Old Jul 27, 2014 | 02:15 PM
blufke's Avatar
TTT!
Old Oct 22, 2014 | 11:24 AM
blufke's Avatar
Bump! Everything is OBO!
Old Oct 26, 2014 | 09:36 AM
blufke's Avatar
Everything that is still listed is still for sale. Interested in hearing reasonable offers!
Old Nov 11, 2014 | 02:44 PM
blufke's Avatar
Everything is OBO! Moving soon and need to sell as much as possible.
Old Feb 19, 2015 | 07:29 AM
blufke's Avatar
Everything is OBO. Cambridge MA now.
Old Feb 22, 2015 | 12:39 AM
D.B.ate's Avatar
You have pm
numbnuts22715
Jan 18, 2007 06:20 AM
batchhatchboy
Jun 10, 2004 03:14 PM
Drewh22a
Aug 20, 2003 10:02 PM
dtec
Aug 10, 2003 02:25 PM
