92 Accord Fans won't run
Old Apr 17, 2014 | 08:07 AM
Realtech's Avatar
Default 92 Accord Fans won't run
So first off, I apologize as I'm sure this topic has probably been beat to death, but I'm stumped here.
Picked this 92 Accord up a few months ago. The cooling fans will not run at all, even with the ac on. The compressor is kicking in. The radiator side fan motor is locked up - I have a new one on its way - but neither fan receives power either. Condenser fan runs when jumped. I have been searching and am going to try jumpering the thermo switch connectors, but would a failed thermoswitch prevent the fans from receiving 12v when ac is on also? Anything that can point me in the right direction is appreciated.
Thanks.
Old Apr 17, 2014 | 09:05 AM
NerfGunner420's Avatar
Default Re: 92 Accord Fans won't run
DID YOU SWITCH FAN RELAY WITH ANOTHER ONE IN THE FUSE BOX?
Old Apr 17, 2014 | 09:56 AM
Realtech's Avatar
Yes, switched fan and power window relays. Relay is good.
Old Apr 17, 2014 | 02:22 PM
I WOULD REMOVE THE FAN TIMER AND REMOVE FROM ITS CASING AND CHECK FOR CRACKS IN THE CONTACT POINTS LIKE YOU DO ON THE MAIN RELAY.
Old Apr 17, 2014 | 02:45 PM
MIGHT WANT TO FOLLOW UP ON THIS FIRST
brimac
Aug 25, 2014 05:09 PM
99HORSEPOWER
Oct 24, 2012 03:08 PM
zrsm9
Aug 13, 2010 08:13 AM
sdlong92
May 25, 2008 10:21 AM
rhodes2010
Sep 3, 2007 09:44 AM
