HELP radiator problem
Old Apr 15, 2014 | 12:39 PM
onlygirls1995's Avatar
Default HELP radiator problem
I have a 95 prelude h23 that has been having some problems with the radiator. Scince i blew my headgasket i have replaced the following parts(headgasket , waterpump, timing belt, thermometer , radiator cap) and flushed both radiator and engine multiple times untill i got all the oil out of the radiator and all the water out of the engine but still my car overheats for no reason, i have been going crazy over this problem someone plz help
Old Apr 15, 2014 | 12:50 PM
bamaland601's Avatar
Default Re: HELP radiator problem
check your heater core lines, hook up a water hose to them and make sure they flow thru.
heater core lines and heater valve. behind Intake Manifold
back of block right above oil filter
Old Apr 15, 2014 | 04:17 PM
snobordboy's Avatar
Moderator
Make sure the thermostat is installed in the correct direction, and working properly. Make sure the system is fully and correctly bled of all air.
Old Apr 16, 2014 | 10:12 AM
crazes's Avatar
Moderator
Also make sure that both lines to the radiator have fluid in them circulating. Also verify that your fans are turning on when they are suppose to. Your switch my have gone bad if the fans dont turn on.
Old Apr 16, 2014 | 04:59 PM
holmesnmanny's Avatar
Compression test the engine.
Also how did you fix the original overheating issue and the headgasket issue ?
IgnitionZ05
May 5, 2007 10:50 AM
Nocturnal
Dec 2, 2005 08:20 PM
dadado
Oct 25, 2004 07:09 PM
projectM
17
Feb 14, 2003 12:53 AM
