mini me swap help!!!
Okay HT I did a mini me swap on my hatch '92 (d15b/z6) I had the head rresurfaced used cometic head gasket copper sprayed and torque down in 2 step sequence. But for some reason I keep overheating and my cool and is low I have no visible leaks and my oil is clear from coolant has anybody ever seen this problem please advise no bashing please
First off, you don't use copper spray on Honda head gaskets. Second off, did you re-use your old head bolts? You shouldn't do that on a Honda either. You said you had the head resurfaced, but did you check the block for warpage? You should always check the head and the block.
Do a block test to confirm, but you probably installed the head incorrectly.
If you loved me, you'd all sell me your magic cards to me today
vaypourus
Oct 31, 2006 11:08 AM
simplypinoyy
May 20, 2004 11:31 PM
