Cams for my turbo?
Alright guys as i piece my turbo together i wondered i currently have Skunk 2 stage 2 race cams from my N/A setup which i will be getting rid of cause i know that they would not suit a Turbo setup. Now my question is i have my stock B16 cams still and thinking i should use those. I hear that using GS-R cams would be better?.
Not sure, what do you guys think?
Thanks
gen2teg
Thanks
gen2teg
i would say the GSR cams would perform better.
Rob
Rob
Are you referring in comparison to the b16 cams or my skunk2 cams?
thanks
gen2teg
The overlap in the cam profile for vtec hinders performance on turbocharged applications, however this overlap is needed for vtec. NA cams will be much more aggresive of course, and will utilize vtec. I think you can take it from there...
gsr cams have no overlap they work great on a turbo.
gsr still has more overlap than a b16. please do a search on this people.
Heres what I have:
B18C
Intake Opens: 10 degrees BTDC
Closes: 40 degrees ABDC
Lift: .423"
Exhaust Opens: 40 degrees BBDC
Closes: 7 degrees ATDC
Lift: .378"
Overlap = 17 degrees
B16A
Intake Opens: 15 degrees BTDC
Closes: 45 degrees ABDC
Lift: .412"
Lift: .379"
Overlap = 22 degrees
Where do you get your specs?
Heres what I have:
B18C
Lift: .423"
Lift: .378"
B16A
Lift: .412"
Lift: .379"
Heres what I have:
B18C
Lift: .423"
Lift: .378"
B16A
Lift: .412"
Lift: .379"
thanks
gen2teg
Jdm_Ej8_Sedan
Feb 25, 2014 05:04 PM
SIReg9
Aug 13, 2003 03:18 PM
