99 accord- where is this trans leaking from??
Old Apr 14, 2014 | 03:42 PM
gearhead899's Avatar
Default 99 accord- where is this trans leaking from??
hey guys. Finally got my new/used trans shifting issues figured out but it has a leak. only while running but doesnt leak at all when shut off. it appeared to be from the passenger axle seal. it was wet all around the passenger side rear part of the trans. so i just swapped that out and its still leaking! is there anything else in that vicinity that would leak? I just cant find the source. you think the lucas trans stop leak is a good idea? or could that do more harm then good?
Old Apr 14, 2014 | 04:58 PM
ej7attack's Avatar
Default Re: 99 accord- where is this trans leaking from??
do not use that lucas stuff. im anxious to hear what you did to fix your issues seeing as your last thread you said you had the p0740 code and such. maybe that solenoids gasket or anything with an o ring you may have disturbed. vss o ring, main and counter shaft o rings. how you fix your previous shifting issues?
Old Apr 14, 2014 | 05:16 PM
the shifting issue just ended up disappearing on its own and same with the CEL. I was surprised and relieved lol but all the solenoids etc are on the front of the trans and no signs of a leak anywhere around them or toward the front of the trans. Its more around the rear and is dripping to the ground right where the shift linkage is attacked. not sure what in that area could be leaking
Old Apr 14, 2014 | 05:21 PM
ej7attack's Avatar
nice. I wish I was that lucky with my replacement on my accord earlier this year lol. besides the axle seals you have mentioned I don't know. perhaps someone who does will chime in. I do wonder if there is some kind of seal around the gear shifter mechanism where the shifter cable attaches.
Old Apr 14, 2014 | 05:55 PM
I don't remember there being anything but I will have to unbolt the cover and double check
Old Apr 15, 2014 | 12:28 AM
holmesnmanny's Avatar
If you used an aftermarket axle seal you must put a glob of grease on the inner lip of the seal or it will tear as soon as it's started up and it will leak. Perhaps not always but most of the time.
Honda seals come pregreased and don't need to be greased.
Old Apr 15, 2014 | 05:15 AM
it was an oem one. i even took a bit of ultra black RTV and smoothed it around the outside of it for extra insurance. but its leaking exactly the same as it was before so I dont think its that. also axle seals usually seem to leak when the car isnt running as well which it does not.
Old Apr 15, 2014 | 01:22 PM
could possibly be either of the two shifter seals ... one is a seal the other is a boot
and u dont put rtv .. it will never leak past the outer lip
Old Apr 15, 2014 | 01:45 PM
ook I figure the rtv couldn't hurt lol and I suppose if I remove the couple bolts holding the metal cover on over the shifter mech that I will see the seal? how hard is it to replace?
Old Apr 16, 2014 | 11:24 AM
Ok so this morning I jacked it up and crawled underneath again. Checked the shifter shaft seal and it was bone dry. Still appeared to be coming from axle seal. I ran the car while I was under it and no dripping. But then lowered it down and went around the block then checked underneath and it was dripping again. Called Honda and ordered a new axle seal. Hopefully this fixes it tomorrow
Old May 8, 2014 | 01:04 PM
Ok guys, its been a while since my last update but i wanted to keep you guys updated. I put in a new oem axle seal and still had a leak. After being fed up because i couldnt figure out where the leak was coming from i got some lucas trans fix. Was nervouse about using it but couldnt think of anything else to do. Directions said to put in about half the bottle for smaller cars so i put in a little less then half. After about a week i noticed the leak had slowed down considerably. Last week after topping off the trans level again i added a little bit more of lucas to equal half a bottle total that i put in. Today while doing a oil change on it i didnt see any moisture at all under the trans. Drove it a bit and checked again and no drips. It appears the lucas has worked!!
jmh51193
Jan 12, 2015 04:21 PM
Schoust
May 13, 2013 12:36 AM
mnbrant
Transmission & Drivetrain
Apr 27, 2013 06:24 AM
jcblackek
Jan 19, 2011 01:00 AM
Dave1821
Dec 8, 2009 08:32 PM
