switching intake manifolds between d16z6 and d15b7
Old Apr 14, 2014 | 10:28 AM
PrettyMuchBoned's Avatar
Default switching intake manifolds between d16z6 and d15b7
read that this is a good mod for the d15b7, to port match the head to the larger intake. I was told the d16z6 is the manifold I should use.
What do I do about the Intake Manifold Gasket if I port the z6 intake larger too? As in, not just port match the head, but rather port them both even larger edited to original post hopefully so it gets answered
is the d16y8 manifold any different? I imagine it would be easier to find.
concern 2: is this gonna negatively affect the d16z6 beyond loss of power?
3: just thought of this, are the injectors the same volume?
Last edited by PrettyMuchBoned; Apr 16, 2014 at 08:01 AM. Reason: back to normal cuz whatever
Old Apr 14, 2014 | 12:10 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: switching intake manifolds between d16z6 and d15b7
it wont hurt the z6, and without a tune, it won't help the b7 much. the y8 manifold is nice, there is controversy about the number 3 (iirc) runner on it being a different length and causing issues. the z6 is very very close to equal length runners. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/d16z6-intake-manifold-vs-d16y8-intake-manifold-2684919/
Old Apr 14, 2014 | 01:45 PM
I sorta just wanna practice porting. I should prolly practice tuning with this junky d15 too.
Last edited by PrettyMuchBoned; Apr 16, 2014 at 08:00 AM. Reason: undid 'other shit' im allowed more than one thread for once
Old Apr 14, 2014 | 04:36 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Originally Posted by eghatch9295
it wont hurt the z6, and without a tune, it won't help the b7 much. the y8 manifold is nice, there is controversy about the number 3 (iirc) runner on it being a different length and causing issues. the z6 is very very close to equal length runners. https://honda-tech.com/forums/showthread.php?t=2684919
After reading that thread, should a Y8 IM be preferred on a Y8 head, or would you see more with a Z6 IM on the Y8 head?
I'm sort of guessing the Y8's 3rd runner being shorter by design had to do with the Y8 head to even out flow or something.
Old Apr 14, 2014 | 04:41 PM
And whats the best way to tell the difference between the Z6, y8, and b7?
I'm not sure where to look for stamps or w/e
Old Apr 14, 2014 | 08:57 PM
most people with a y8 just keep its manifold. for my build, ill be using a z6 manifold/head on an a6 bottom end. i cant justify the possibility of running lean with the y8 under boost. read- http://www.d-series.org/forums/natur...-once-all.html as far as telling them apart, google image them.
Old Apr 14, 2014 | 09:46 PM
thanks for posting links.
Last edited by PrettyMuchBoned; Apr 15, 2014 at 10:14 PM. Reason: deleted 2 cuz i asked the question 3 times so someone would notice
Old Apr 15, 2014 | 01:29 AM
HondaPartsHero's Avatar
Technical Hero
http://civic-eg.com/viewtopic.php?t=3340
Old Apr 15, 2014 | 04:38 PM
Neocaspian's Avatar
Since no one has answered this question yes the injectors are the same size, as a matter of fact I think all the fuel injectors on civics are all the same size excluding the VX model I think.
Old Apr 15, 2014 | 05:22 PM
NotARaCist's Avatar
I never narc'd on nobody!
The D16Y7, D15Z1, and D16Y5 have smaller injectors than other (modern) D series engines. Most D series engines have a 240cc/min injector. The Y7 has 170cc/min injectors, and the Z1 and Y5 both have ~185cc/min injectors.
Old Apr 15, 2014 | 06:43 PM
/\ truth. and neo, nobody asked... lol. can you run the smaller injectors? yes, but with the 240cc ecu's, youll overwork them, leading to failure.
Old Apr 15, 2014 | 08:13 PM
Eghatch9295, I edited the first post to include that question when I thought of it. I remembered reading that a few engines have different volume injectors, but I couldn't remember if the b7 did. I didnt wanna run the risk of blowing up good injectors by not switching em if I put the b7 I/M on the d16z6. I'm hoping just to find another Z6 manifold, though. Gotta check more junkyards
Old Apr 15, 2014 | 09:18 PM
NotARaCist's Avatar
An exacto knife.
Old Apr 15, 2014 | 09:59 PM
Originally Posted by NotARacist
An exacto knife.
that simple huh? Cool, thanks man.
Old Apr 15, 2014 | 10:58 PM
the gaskets are just paper composite.
Old Apr 15, 2014 | 11:04 PM
IV always used proper gaskets before, never made my own or anything so I didnt know what the correct way of doing it was.
thanks for all the advice everyone. I'm sure I'll have more questions before I'm driving the EJ2 around again. Then ill get to finish all the bodywork on the sedan. Hooray fixing windshield lip. Really looking forward to that..
anymore mods I should do the black car while the head is off? The compression already seemed high but I was thinking about bringing the head somewhere to get shaved anyway for good mating surface + bump in compression.
Old Apr 15, 2014 | 11:22 PM
be careful with adding compression without a proper tune.
Old Apr 15, 2014 | 11:37 PM
do you know if the OEM ecu in my 95 DX coupe is chip-able? I read so many times to use a p28 that its what I thought the right thing to do was. Its not like I have vtec though, so is that gonna be a problem?
Old Apr 16, 2014 | 12:47 AM
Technical Hero
Put D15B8 (92-95 CX) on that list of 180cc
Old Apr 16, 2014 | 01:10 AM
yes, your p06 is chippable. you don't want to run a p28 on your b7. will throw a cel for vtec solenoid/pressure and keep you in limp mode. not to mention, wrong fuel maps, etc etc
Old Apr 16, 2014 | 01:33 AM
I had a suspicion that it would give me a CEL. I dont want that, IV gotta get a dumb inspection sticker as soon as I get the car fixed. Mine expired a month ago.. Since I'm thinking of computer b/s now
which ECU chip has the best cost benefit ratio?
Old Apr 16, 2014 | 09:25 AM
NotARaCist's Avatar
There is no "best chip". When you start looking at chipping, you should start with a basemap from a reputable company (I'm a fan of Xenocron), and use that basemap to drive the car to a professional tuner.
Old Apr 16, 2014 | 11:13 AM
I'd rather become competent myself. My brother has been tuning his rotary engines for a while, I figure I can learn how on a d15, lol. Plus IV been takng tuner classes
Old Apr 16, 2014 | 11:44 AM
NotARaCist's Avatar
Then get yourself a Moates Ostrich 2, a chip burner, a few blank chips, and a wideband, and go to town.
Old Apr 16, 2014 | 11:48 AM
thanks for the advice, ill be getting into this in a few weeks. Parts to fix the engine will be here this week/next week
Jonknee
Jul 23, 2007 03:47 PM
vha27
Dec 2, 2003 09:38 AM
RoAnSa
Sep 15, 2003 06:27 AM
J-Spec EG Sleeper
Jan 9, 2003 02:06 AM
