95 Civic won't pass emissions test! High CO
Old Apr 13, 2014 | 12:41 PM
PhilDrach's Avatar
Default 95 Civic won't pass emissions test! High CO
Guys, I have a 1995 Honda Civic and it has failed its last 3 emissions test because of high CO levels. I need tog et it under 1.07%. The first time it was at 2.8%, then 2.6%, then 2.0%. I have been going to a local shop and I trust the guy. He has replaced the O2 sensor. He also cleaned out the catalytic convertor because there was a lot of carbon build-up in it and he told me to keep filling it up with premium gas and to put in an engine cleaner when I go and fill up and then to keep driving it a lot before I get it tested again.
Now I was at Valvoline the other day getting an oil change and I asked the guy about it and he said that in Honda's over time the "idol control solenoid" goes bad and makes the engine sound like:
I had gotten an oil change at Valvoline and I asked the guy there about it and he said something about an idle control solenoid which I know nothing about. Then I heard something about a possible vacuum leak? Looking for some help in diagnosing this.
Old Apr 13, 2014 | 12:59 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 95 Honda Civic won't pass fuel emissions test!
Putting in premium gas is a waste of your money.
Post the emissions sheets.
Old Apr 13, 2014 | 02:15 PM
JoeBlue's Avatar
My bet is on your air filter. You do know that you should clean that thing every once in a while right?
Old Apr 13, 2014 | 04:39 PM
Former User's Avatar
Both^
ElCivic89
Sep 13, 2013 11:14 AM
colnago
Mar 29, 2011 12:22 PM
asonoasono
Honda CR-V & Element
Jan 10, 2011 07:06 AM
AK_CRX
23
Mar 3, 2009 04:31 PM
blackhatchsd
Feb 24, 2007 04:10 PM
