whats the best shift points for a d16y7 in a ef sedan?
Old Apr 11, 2014 | 01:10 PM
d16efsedan918's Avatar
Default whats the best shift points for a d16y7 in a ef sedan?
like the title says what are the best shift points?also what clutch kit do i order for my ef?its got a d16y7 out of a 96 civic in it with an l3 transmission.thing is i ordered kit for 96 and it wasnt even close to matching up.ordered one for an 88 and it was still a hair off what the deuce
Old Apr 11, 2014 | 02:48 PM
F22Master's Avatar
Default Re: whats the best shift points for a d16y7 in a ef sedan?
I wouldnt take it past 7k. Those y7 bottoms ends are notorious for spinning rod bearings because of the weak oil pump.
Old Apr 13, 2014 | 03:06 AM
~sp33~'s Avatar
EFB055
'best'. Subjective.
For performance? For fuel economy? For engine longevity? For smoothness?
Old Apr 14, 2014 | 09:19 AM
i run it just under 7 grand now so since they have week oil pumps do i try and find a better one?i need a good performance clutch kit for the car i have a stage one that should be here tommorrow but its just the disc.i need a new flywheel and pressure plate too.
Old Apr 14, 2014 | 12:45 PM
F22Master's Avatar
You could put a different oil pump in it, and that would help. But you really need to get a new one and port it out to really be safe at elevated rpms and power levels. Search DIY oil pump porting for more info.
Mr.Merz
15
Mar 23, 2015 02:02 PM
pjr710
Mar 31, 2012 08:08 PM
boostedefhatch
Mar 1, 2009 01:17 AM
t3h Gone
Feb 10, 2006 10:51 AM
smuggy
Jan 2, 2003 10:26 PM
