Prelude with moments :/
Old Apr 9, 2014 | 02:14 PM
Z99doc's Avatar
Default Prelude with moments :/
I have a 92 Honda prelude that starts on a regular basis and sometimes just doesn't start.... like the starter will keep going but no spark in the engine i'm guessing... then after you come back to it maybe 5 min later it starts..... i'm not understanding what the issue is. Please help
Old Apr 9, 2014 | 05:00 PM
Sparksman's Avatar
Default Re: Prelude with moments :/
Air, Fuel, Compression, spark and timing is all it can be.
Check ignition timing, the TPS. Maybe bad starter, loose connection/ground, or dead battery.
Next I would try a compression leak down test if you havent fixed after checking all those.
Old Apr 10, 2014 | 12:35 PM
Z99doc's Avatar
could water in the fuel cause this also and i just kinda realized it only does it on warmer days.... for instance this morning (it was cold outside) it started and ran just fine this afternoon (it was hot out) it was doing that thing again where it was trying to start but wouldnt.
Old Apr 10, 2014 | 02:25 PM
snobordboy's Avatar
Moderator
I am not a betting man, but I have a nickel that says it is a main relay issue. Using Google or the search on here should find you some answers.
Old Apr 10, 2014 | 02:48 PM
yohan's Avatar
main relay x2.
When you turn your key forward to ignition i (before cranking) you'll normally hear a "tick" come from under the dashboard, this is the main relay clicking on. If you don't hear that click, it's likely failed.
Old Apr 22, 2014 | 04:43 PM
Z99doc's Avatar
It was the main relay Thanks guys
Old Apr 28, 2014 | 06:26 PM
93_BB2_Prelude's Avatar
My 93 did the same thing and I couldn't figure out what it was could be the main relay. I ended up replacing the starter and it fixed the problem. But good luck on fixing your problem.
si_motor_spt
Aug 17, 2022 10:52 AM
dcskater56
Dec 22, 2009 06:46 PM
LSBeast
Jan 19, 2008 07:41 AM
cindysi
Oct 11, 2006 09:15 PM
outkast_teggy96
Jun 14, 2006 03:29 PM
