changing MT fluid in '94 accord (plus dist cap question)
My manual tranny is not grinding but it's a little rough when shifting so I want to replace the fluid. Should I go get MT fluid from a Honda dealer or is there a fluid at O'Reilly or Napa that will work? Also, I will need two crush washer replacements, one for the drain bolt and one for the fill bolt, correct? What are the torque specs for these two bolts when I reinstall them with new crush washers?
My second question is about the distributor cap... When you remove the cap and reinstall it, do you have to replace the little spring/lock washers on the 3 bolts that hold the cap on, or can they be reused? What about when you actually replace the cap with a new one? Btw the bolts on my dist cap actually come out, they aren't fixed to the cap like some are.
