hondata s300 not reading sensors?
Old Apr 8, 2014 | 07:45 PM
m4xwellmurd3r's Avatar
So I just tried testing out my p06 ecu in my friends car. Threw a basemap amd adjusted for injector size and fuel pressure (he has it bumped up for whatever reason)
Ecu took the calibration and fired right up. I hit data log and nothing.
J12 was still in so I desoldered it out
Put the ecu back in the car with the same map and now it still wont read any sensor input and instead of water and air temp showing 32f they show 302f.
Still wont show any sensor inputs of I try to datalog. Am I missing something? It takes calibrations fine, no error codes, no cel.
Its a p06 woth boost control installed.
Under the sensor tab previously it was showing 0 for all sensors. After, most showed zero but timing showed -4 and tps showed 12%. There were a few other things too.
Did I miss something? When I tried recording the data it just didnt do jack squat
Ok guys I feel like a noob.
I popped the case off my ecu, hooked up my harness, turn the key. 2 green solids, one flashing red. Looks like s300 is doing onboard datalogging.
That explains why I dont get any realtime sensor info through smanager
cleanazcoupe
Engine Management and Tuning
Jul 1, 2009 10:55 AM
watsvtecEK
May 10, 2007 02:03 PM
otakueric
Sep 13, 2005 04:49 PM
turbosi03
Jul 11, 2005 01:34 PM
rev limiter
Mar 6, 2005 10:36 AM
