99 accord swap issues
Old Apr 8, 2014 | 09:21 AM
Mikevar82's Avatar
Default 99 accord swap issues
Hey guys. I have a 99 accord auto ulev motor. I had issues with the engine so I found a good ulev motor out of an 02. I installed it This weekend and fired it up. Fires up fine, but won't rev past 1500 RPM and wants to die after you rev it. I have no codes coming out. I went and bought a new distributor and issue still remained the same. Plugs rotor cap all good. Iam wondering if the crank position sensor are different even though they should be the same. Even if bad I think it should give a code right away. Any ideas guys?
Old Apr 8, 2014 | 11:36 AM
CoryDHorne's Avatar
Default Re: 99 accord swap issues
Have you checked the timing? Also, fuel injectors?
EDIT: Also, a buddy of mine had this problem (with a truck) and it ended up being his fuel pump.
Old Apr 8, 2014 | 12:33 PM
Mikevar82's Avatar
Glad you mentioned timing. I didn't get a chance to check it but as I was installing the distributor I realized its fixed position. So how would you adjust timing assuming its off.
Old Apr 8, 2014 | 11:06 PM
MAD_MIKE's Avatar
MM Gruppe B
I believe starting in '96 the distributor cannot be adjusted. If timing is off the camshaft timing belt may be loose or out of alignment.
Are you reusing our old intake/exhaust manifolds, or did you 'new' engine have those parts and you are reusing them?
Check for basics, fuel, spark, air.
What were the issues with the original engine?
Old Apr 9, 2014 | 02:55 AM
Mikevar82's Avatar
Yes Iam reusing everything off my old motor which I know where working fine on the motor before, except crank position sensor. Old motor had a cracked head or leaking HG, it still ran fine. Except for smoke upon start up. Iam pretty stumped here. I checked spark seems good, fuel seems good. It starts up and idles fine but won't rev. Any other ideas guys?
Old Apr 9, 2014 | 03:26 AM
tim73's Avatar
Go to rockauto, and pull up both a 99 and an 02, look at the part numbers for the various sensors. See if all are the same.
Old Apr 9, 2014 | 03:51 AM
Mikevar82's Avatar
Just check comes up same part number. Any one know the procedure to test the sensor?
Old Apr 9, 2014 | 01:47 PM
holmesnmanny's Avatar
check mechanical timing again and then compression test it
Old Apr 12, 2014 | 04:57 AM
Lost Again's Avatar
What color are the three wires going to the MAP sensor?
Old Apr 12, 2014 | 07:06 AM
Mikevar82's Avatar
Hey guys problem solved in two seconds. I hooked up the TPS sensor and the one on top of throttle body wrong. Swapped them and its all good now. Bone head move! Thank you all for your help.
Old Apr 12, 2014 | 02:06 PM
u'd be surprised how many people do that
Old Apr 13, 2014 | 04:47 AM
Lost Again's Avatar
So true, that is why I asked about the wire colors
MrTorres
Apr 14, 2017 07:15 AM
genesun56
Oct 7, 2015 07:32 AM
reddcoupe
May 20, 2015 08:32 PM
Coug 77
Feb 14, 2014 05:28 PM
SW20FL
Feb 11, 2011 05:48 PM
