Classic Hondas All Pre-1988 Hondas.
transaxle swap on stock 86 Crx si
Old Apr 6, 2014 | 12:08 PM
92 civic ex 4dr's Avatar
Default transaxle swap on stock 86 Crx si
I have a stock Crx. Stock engine and everything. I'm curious if I could do a transaxle swap and what would bolt up. The car is already a 5 speed and I want to keep it that way or 6
Old Apr 7, 2014 | 05:02 AM
ej1995's Avatar
Default Re: transaxle swap on stock 86 Crx si
what are you trying to gain from changing transmissions? also, 6 speed will not happen...period.
Old Apr 28, 2014 | 09:39 AM
Yeah I figured a 6 speed was out of the question. What I'm trying to gain by a transaxle swap is gearing change. Something to help ruin at a lower rpm on the freeway.
Old Apr 30, 2014 | 11:36 AM
ej1995's Avatar
Get a 5 speed from a CRX HF.
Old Apr 30, 2014 | 02:57 PM
Ok. Now I'm not familiar with the crx's. Fourth and fifth gen civics third fourth and fifth gen accords yes. Which crx is the hf?
I should probably mention that my rex is a si
Old May 1, 2014 | 06:47 PM
ej1995's Avatar
Right, the Si models have different gearing than the HF. HF cars were geared more for fuel economy, as opposed to the more performance oriented ratios in the Si transaxle.
HF is a trim level, not a chassis code, just so you are aware. I think you were assuming that HF was a chassis code like ED, EG, EK, EJ, and so on. The HF trim, 1st generation CRX is what you are looking for.
jdm.norcal
Northern California (Sales)
Feb 18, 2009 08:21 AM
glennxx1
Jul 8, 2008 02:36 PM
l2ex
Jul 24, 2001 02:56 PM
