Flywheel bearing
I have a obd0 block built and im running a CC Twin disk and ia throw out and pilot bearing i got from CC. The pilot bearing sits flush on the flywheel but has play on the crank? My last setup it sat flush on both flywheel n crank but was a obd1 gsr block. Any different in Crank? It goes in but has play all around like th bearing is small and the crank hole is bigger. Any input thanks
Ransom
Feb 21, 2007 07:24 PM
