D15b7 wiring help
Hey my new her my name is Marc am from the off-road world. I do metal fab an rock crawling. The reason am here is about 5years now ive been waiting to put a honda motor in a crawler you turn the motor side ways an it's a rear
Engine. But anyway am here for wiring help an I've done tons of research so please don't bash me for wanting to learn.lol
Thanks. Am wanting to do a stand alone harness that just
Runs motor. Not sure what plugs I need just to crank an run it. So help
Finding a good clear diagram an a list of plugs that I need to keep. Would be great. Any info would be great. Here's a few pics of the rig.
Red lines are the driveshafts
Thanks again
Thanks again
Your best friend will be the Helms manual. A google search for 92-95 civic FSM should turn you up with a place to download the Factory Service Manual.
It has all the electrical for it.
Quite the project you got there. Not sure why you are transplanting an economy motor into your rock crawler. Then again, I guess rock crawling never really gets into the above 5K rpm range for Vtec so would be a waste maybe....
Anyways, good luck.
Anyways, good luck.
I'm just learning the wiring to these old motors due to my wifes car so I'm no guru.
One thought I did have was I think it would depend on how you were going to go about it, if you were going stock ECU, I tend to think you'd need to save a lot more than you may want, while if you went with an aftermarket engine management system like AEM or Hondata S300, you could probably do away with a lot and have the most basic wire harness.
But like I said, I'm no guru on it, I'm really am just a pupil.
Here is just a basic list of the sensors and the codes the ECU will throw when things are awry with them:
The D15B7 doesn't have the EGR. That would be on the D15Z1 engine. The D15B7 also doesn't have the Valve Timing Oil pressor bit. I am not sure about the PA sensor, haven't looked at that one.
If you're going to keep it fuel injected and running of a Honda ecu pretty much everything has to stay as is.
There's only a couple of things in the harness not related to running the engine. None of them are worth ripping the haness apart to remove.
Oil pressure sender, reverse light wiring and cooling fan thermo switch are the ones that come to mind off hand.
