car wont stay at idle
Old Oct 29, 2002 | 06:26 PM
rustycivic's Avatar
Default car wont stay at idle
i got a b16a in my 90 hatch and it wont stay at idle.....when the car is cold itll stay at about 2 grand then once it warms up the idle will fall below 1 causing the car to die?????? ive checked all my vacum lines and throttle cable but no matter what i do the idle wont hold at 1 and car just keep on dieing? do you guys have any idea on what can be causing this??? any help is appreciated..thanx
Old Oct 29, 2002 | 07:32 PM
altoid's Avatar
Default Re: car wont stay at idle (rustycivic)
check your solenoids for proper functioning, thats all i can think of, did you have any hoses left over?
Old Oct 29, 2002 | 11:46 PM
rustycivic's Avatar
Default Re: car wont stay at idle (altoid)
nope no hoses left over! ???????
Old Oct 30, 2002 | 07:40 AM
Token Blk Guy's Avatar
So what I drive a Volvo
Aslo check to see if you have a vacum leak. Make sure there are no holes in your hoses, this will cause your **** to idle crazy!
Do you have the A1 or A2 i would assume the A1 since it is a cable tranny. Because the intake vacum hoses are different between the 2!
[Modified by Token Blk Guy, 4:41 PM 10/30/2002]
[Modified by Token Blk Guy, 4:43 PM 10/30/2002]
Old Oct 30, 2002 | 07:51 AM
SuperCivic's Avatar
Default Re: car wont stay at idle (Token Blk Guy)
try adjusting your idle. you can take a can of carb cleaner and spray it around the intake while the car is running to find vacuum leaks. but it sounds to me like the idle needs to be adjusted up.
Old Oct 30, 2002 | 08:23 AM
Doodoo's Avatar
Have you checked or messed with your fuel pressure? Mine dies at start up because of overfueling cold start. Sometimes at a light it will start to flood also if it idles too long. check it out.
ONECLEAN91
Mar 16, 2011 04:58 AM
96gts4.6l
Feb 10, 2009 01:27 PM
RedR
Aug 4, 2008 04:38 PM
90si-rex
Jul 27, 2006 05:54 PM
headhunter
Aug 18, 2003 08:14 PM
