oil takes a while to drain back to pan h22a4?
Old Apr 3, 2014 | 04:53 AM
kevin j's Avatar
Default oil takes a while to drain back to pan h22a4?
when i check the oil level after just driving the car it appears a quart low, but if i let it sit for an hour i magically have my missing quart back. anyone else have this issue? could it be a blocked oil passage because i also have excess crank case pressure. would a quart of atf help?
the engine has 150k, i just got it and do not know the previous maintenance.
Old Apr 3, 2014 | 06:51 AM
snobordboy's Avatar
Moderator
Default Re: oil takes a while to drain back to pan h22a4?
It takes 5-10 minutes for most engines to really drain back fully, and thick oil, clogged filters etc. may take longer. You could have some head passages gummed up a bit from dino oil, but it shouldn't hold a full quart for too long up there.
With that kind of mileage on the engine, I would not worry too much, just keep up with oil changes and watch the level. If you try to run any cleaners or such through, you might end up causing leaks by breaking down the layers that have built up over the years.
Old Apr 3, 2014 | 04:39 PM
holmesnmanny's Avatar
completely normal oil behavior
EGgoJDM
Dec 1, 2009 12:05 PM
iGGY366
Honda Civic (2001 - 2005)
Dec 6, 2007 02:17 AM
CRXstress
Sep 27, 2004 10:01 PM
dose
Aug 8, 2002 09:20 AM
onyx00
Feb 22, 2002 11:54 PM
