complete cleanout alot of b series oem and alot of other stuff
cleaned out my storage and need to sell all this stuff to make room, prices do not include shipping or paypal fees,
pm or text with any questions 630-677-8779
B SERIES PARTS
blox fuel pressure regulator $20
b16 oil pan with pickup and windage tray $25
b20 oil pan with pickup and windage tray $25
b20 crank pulley SOLD
b series axles SOLD
b20 lower timing cover $5
b16 oil pump $20
gsr timing belt side aluminum mount $20
b20 almost new oem honda water pump $30
intermediate shaft $30
trans torque mount/bracket with 3 bolts $20
ac bracket/ torque mount with bolts SOLD
ac compressor plug broke off $25
starter SOLD
alternator brackets $10 set
b18b1 crank pulley $5
b series 2 bolt post mount $5
b18b1 flywheel needs resurfacing $10
flywheel bolts oem $10
miscellaneous throttle cables $5 each
MISCELLANEOUS PARTS
40/40 proportioning valve SOLD
1" master cylinder SOLD
db8 brake booster SOLD
positive and negative remote battery terminals SOLD
gsr leather arm rest $30
eg si airbox whats pictured $20
miscellaneous AN lines(look at pic) offer
dc cluster good working condition $30
ek ex front calipers with bracket $20 for both
eg cluster wiring harness $25
pile of harness plugs(look at pics) make offer
99-00 si front lip hardware in nib (bolts and clips) SOLD
d16y5 fuel rail $5
d16y8 arp head studs torqued once $40
5 bolt turbo downpipe SOLD
eg stock fuel filter assembly with bracket,stock line and pressure gauge $10
eg manual door panels need cleaned up $20
95 eg si front seats need a little cleaning thats it $50 for both
fixed back bucket seat no rail or sliders $30
88-89 ef si front passenger seat good condition needs cleaning $25
db8 black door panels all 4 $50
K20 PARTS
k20a2 stock injectors $20 for set
k20a2 stock clutch more than 50% life left $25
k20a2 slave cylinder $10
k20a2 coil cover $5
k20z3 coil cover $10
k20a2 stock timing side mount bracket $5
ktuned k swap heater hose kit new SOLD
if you see something in the pics you need that isnt posted let me know
not pictured but will have pics soon
DC subframe with control arms and power steering rack
DC steering wheel black
DC pedal assembly, i have clutch with master and reservoir, brake pedal and gas pedal
B SERIES PARTS
b series axles SOLD
b16 oil pump $20
starter SOLD
MISCELLANEOUS PARTS
d16y5 fuel rail $5
K20 PARTS
k20a2 coil cover $5
Do you have two down pipes for sale?
Just wondering....I see a $3 and a $30.......might be interested either way. ...Price shipped to 49112?
EDIT: It is in the top left corner of the first picture.
ek9kbomb'd
Apr 18, 2014 05:55 AM
Spoon84
Aug 11, 2010 04:56 PM
