2002 Acura MDX transmission codes !!!!
The p1750 shows this service news: Internal failure. will need to either replace the trans or rebuild it.
A/T Solenoid Replacement
Criteria
NOTE: This article applies to ’99–04 Accords,
’01–04 Civics, ’02–04 CR-Vs, ’03–04 Elements,
’99–04 Odysseys, and ’03–04 Pilots.
The diagnostic procedures in our S/Ms were
written before we had solenoid replacement data.
To cut down on unnecessary solenoid
replacement, don’t replace solenoids if any of
these criteria are met:
• The odometer has more than 20,000 miles.
• The vehicle has a reman A/T.
• The ATF is contaminated with friction material
or metal.
• The axle seals are leaking or the differential
carrier bearings are loose.
• The A/T makes grinding or whining noises.
Criteria
or metal.
