oil in spark plugs?
Old Apr 1, 2014 | 05:41 PM
jay.tee's Avatar
Default oil in spark plugs?
hey ht, ive got a d15b2 and ive got oil in the spark plug and alot of it. no throtle response and bogs a bit. after a quick run around the naberhood theres a ton of heat comin off the motor but the temp gauge say its barraly wormed up, and smoke idk whts goin on can u guys help me out. is my motor done? btw its got 230,000 + miles
Old Apr 1, 2014 | 07:59 PM
Glowicki's Avatar
So, there is oil in the spark plug tubes? Easy fix... Go to you local Autoparts store and get a set of spark plug tube seals and a valve cover gasket while your at it. Should cost about $15-$20. I know autozone an oriellys carries them.
The bogging down is probably being caused by the oil in the spark plug tubes making the connection between your plugs and plug wires weak.
Old Apr 1, 2014 | 09:43 PM
jay.tee's Avatar
Default Re: oil in spark plugs?
no i did that its not in the tubes but all over the threads and electrode not giving it proper spark but where is the oil coming from? bad head gasket?
Old Apr 1, 2014 | 09:57 PM
Ef4doorwagon's Avatar
Did you change the 4 o rings on the bottom of rocker arms?
Those go bad after a while.
Order a set from the dealer( like 2$ an o ring) theres 3 regular o rings and one thats a figure 8.
Then just take your rocker arm assembly off( leave the bolts in place so you dont have to re assemble it) and flip it over, youll see the o ring seals im talking about. If theyre stiff or they brake as you try n pull them out, then thats the culprit of the oil mess. Hope this helps.
Old Apr 2, 2014 | 12:39 PM
jay.tee's Avatar
oooooh no i didnt, im ganna take a look at that. thanx for the info, and sorry for the question.
Old Apr 15, 2014 | 09:23 PM
dom_ef1992's Avatar
check you valve cover gasket. oil might be leaking from the valves. Yours tubes could be perfectly fine and it will still leak into there.
Old Apr 15, 2014 | 09:49 PM
lew003's Avatar
I have the same problem here I got a 91 civic dx hatchback.
Old Apr 20, 2014 | 12:32 PM
hoga113's Avatar
Change the number 2 and 3, and see if it still oil in your spark plug tube. Get Hondabond, and put a light coat of it on the red mark on the picture, put both side (cam gear side and distributor side). Keep the hondabond in ziplock bag.
Old Apr 23, 2014 | 01:45 PM
jay.tee's Avatar
sorry the late reply, been busy job huntin. i did wht all u guys said and the o rings on the buttom the rocker arms fixed it. thanks for the help.
Old Sep 12, 2014 | 04:48 PM
wasp9166's Avatar
you need to change the plug gaskets that are underneath the valvetrain
1998_4dr_gsr
Apr 13, 2011 09:02 AM
aWeimaraner
Jan 25, 2008 10:52 AM
matryx
Dec 15, 2007 01:18 PM
BB6racer
Jan 18, 2006 05:20 PM
illusion
Apr 30, 2003 06:47 PM
