Ignition Switch Trouble
Old Apr 1, 2014 | 08:38 AM
CptHMCrunch's Avatar
Default Ignition Switch Trouble
Greetings,
I am having difficulty getting my vehicle to start and stay running. When the key is in the ON position all of the accessories and blower motor work, but none of the dash lights come on, the blinkers don't work, the fuel pump does not cycle, the CEL does not come on at all or cycle, and the main relay does not cycle.
If I crank the car over it does start and run until I release the key allowing it to return to the ON position. The vehicle stalls when the key returns to the on position.
When I turn the key half way between ON and START the CEL cycles as normal, the main relay cycles as normal, the fuel pump primes, the hazards and turn signals work, but none of the accessories work.
If I crank the car over and manually return the key to half way between ON and START the vehicle runs fine, with no accessories working. I can drive the vehicle if I am physically holding the key between ON and START.
It is as if the connection in the ignition switch is only being closed when the key is physically being held half way between the ON and START position.
I have checked all fuses, but have not had time to run multimeter testing on the MAP or ground continuity tests.
Any suggestions?
Old Apr 1, 2014 | 08:51 AM
ef-hatchcrap's Avatar
Default Re: Ignition Switch Trouble
Change the white plug on the back of the ignition. Its held in by 2 Phillips head screws if I recall correctly. also has a harness that runs to the fuse box.
Old Apr 1, 2014 | 11:03 AM
There is no plug on te back of the ignition. The wires are soldered to the ignition. I took the ignition switch apart and the contact plates that the ignition switch closes seem to be pitted. The contact plates on the inner portion are pitted the greatest. The contacts on the raised outer portion of the ignition don't seem to have any pitting.
Does which wire is the out to the main relay?
88_hatch_ls
Sep 2, 2013 12:25 PM
ImportechPerformance
Jul 26, 2010 07:05 PM
st_rage
Nov 29, 2008 01:38 PM
slowcrxsib16
Jul 31, 2006 07:00 PM
KoRE
Jul 10, 2004 06:18 AM
