98 h22a4 oil light flashes
Old Apr 1, 2014 | 04:57 AM
bigbooms517's Avatar
Default 98 h22a4 oil light flashes
my oil light flashes every now and then.. sometimes when i start my vehicle!! but oil pressure switch is new.. and car is full of oil..
Old Apr 1, 2014 | 06:53 AM
snobordboy's Avatar
Moderator
Default Re: 98 h22a4 oil light flashes
Sounds like you need to test it with an actual gauge. You may have a bad oil pump, or bearings that are loose to the point that oil pressure is not building well.
Be very careful if you start hearing noise from the bottom end, a spun bearing or worse may soon follow.
Old Apr 1, 2014 | 07:08 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Sno has it. Oil pump is bad or is going bad. I would not drive until its fixed. Spun bearings are NOT fun.
Old Apr 1, 2014 | 08:25 PM
thanks guys.. i think its time for a k swap!!!
ricky28
May 12, 2014 03:38 PM
garthjenkins
Aug 6, 2011 01:35 PM
Schultzie
Jul 10, 2010 08:58 PM
antiJDM
Jan 30, 2008 02:32 PM
1999blownlsturbo
Dec 15, 2006 10:32 PM
