2001 transmission rebuild
Old Mar 30, 2014 | 06:50 PM
levifps's Avatar
Icon2 2001 transmission rebuild
Wanted to start rebuilding my 2001 transmission today, after getting the bearings pressed I started to reassemble the transmission and ran into a disaster.
I left the speed sensor installed and then dropped in the LSD, and it looks like I chipped part of the LSD thread that attaches to the sensor or when they pressed in the bearing they messed it up during the press?? I dont know anymore
Some pix attached of the damage, also it seems that when I spin it counter clockwise the sound is very minimal, but clock wise its much louder, when the car is driving is lsd spinning clock wise or counter? If the noise is only going to be in reverse I can live with that.
also a quick video of the sound, at this point any info would be appreciated, fixable? leave it at is it? Get a new LSD? Uhhh
just found this info on the site https://honda-tech.com/forums/transmission-drivetrain-127/b-series-transmission-teardown-rebuild-tutorial-2443459/ it seems that the speed sensor does NOT have to be removed, if that is the case this makes me think the company that pressed in the new bearings messed up.
Old Mar 30, 2014 | 09:08 PM
lzylst's Avatar
Default Re: 2001 transmission rebuild
I don't believe the speedo gear runs on the edge of the drive gear. I don't see it presenting an issue.
Old Mar 31, 2014 | 04:12 AM
levifps's Avatar
You can see the speedo turning at one point in the video, if I remove it the noise goes away, the contact point is that threaded part that's chipped. I might try to file down the sharp edge to see if it will blend in smoother.
Old Apr 2, 2014 | 08:40 AM
TODAwhore's Avatar
Yeah I would try to clean it up, and it does spin clockwise when driving.
how does the gear look on the vss?
Old Apr 2, 2014 | 08:43 AM
levifps's Avatar
you should be able to clean it up... how does the gear look on the vss?
The vss is clean, I found out that the speed ring can be replaced, I just picked one up should be arriving this week, I'll take it to a new place to get the old one removed and press in the new one.
Old Apr 2, 2014 | 12:44 PM
TODAwhore's Avatar
Yeah I was going to say just replace the ring, but when I look it up on the pars catalog it wasn't showing it. I know the k series diff has it... That's good to hear..
Old Apr 2, 2014 | 04:58 PM
ekcoupeh22's Avatar
Looks like it was dropped
Old Apr 2, 2014 | 06:11 PM
tony_2018's Avatar
Fish Twig
Find another
Old Apr 3, 2014 | 09:31 AM
levifps's Avatar
I also picked up a new clutch, after I removed the old one, it seems that the flywheel teeth are moving freely back and forth a bit, is this normal?
https://www.youtube.com/watch?v=bq1v...ature=youtu.be
Old Apr 3, 2014 | 06:02 PM
Punkaddic's Avatar
no it shouldn't move like that and i would get a new one for sure. One piece act prolite is what i had for years and i like it
Old Apr 8, 2014 | 04:51 AM
levifps's Avatar
So I got the new ring I'm going to get it pressed in by another shop. I also noticed that I had a small leak around the oil pan so I got a new gasket and started to remove the pan. after cleaning it out I found this metal in the bottom of the pan, after looking it over I noticed that one of the oil jets under the piston was broken off, how the hell does this happen?
I'm going to replace it with a jet from my old GSR engine that I have for parts, anyone how what could have gone wrong? Before I pulled the transmission the engine was running fine and strong.
EKweezy
Nov 25, 2010 08:42 PM
sp0017
Aug 14, 2003 02:48 AM
meltSolid
Apr 11, 2003 03:33 PM
calitypeR
Jul 27, 2001 06:10 PM
