Complete DRAG CAR Partout! A bunch of parts for sale!
Parting out our project drag car. Open to reasonable trades.
Located in Carson, California 90746
Call or text
424 731 2162 JR
310 961 7175 Rod
*Chassis: $2500
1995 Honda Civic Coupe (Title in Hand)
-MB Products 1pc Fiberglass Front End
-Strada Fiberglass Doors
-Brand new Custom Lexan all around
-Custom Lexan Sunroof Plug
-Custom Rollcage
-Wheelie Bar
-Fresh Paint Job
2-stage (outside)
Single stage (inside)
-Brand new AC Autotechnic Rear Bumper Diffuser 1pc.
-Antenna Block Off Plate
-Brand new Bushings Installed:
Energy Suspension Hyperflex Bushing Kits 16-18103G
Energy Suspension 16.7106G Rear Right Trailing Arm Set
-Newly Rebuilt Rear Brake Drums:
Bendix Brakes 576 - Bendix Brakes Brake Shoes
Bendix Brakes PDR0508 - Bendix Brakes Global Brake Drums
Dorman HW17307 - Dorman Brake Hardware Kits
*$3500(willing to part head & block)- LONGBLOCK: Motor has 0 miles since rebuild. Has new gaskets, seals, rings, OEM water pump, OEM timing belt, etc.
1999 GSR Block (VIN # upon request)
-AEBS T-Sleeves Solid Deck w/ Copper O-Rings (Done by AEBS)
-JE 84mm Pistons w/ Ceramic Coated Tops Nitrile Coated Skirts Straight Wall
-JE Pro Seal Rings (NEW)
-Pauter Chromoly Rods (Standard GSR Length) (ARP 2000 Hardware)
-AEBS Main studs
-ARP Head studs
-Stock GSR crank w. micro polished journals & cryo treatment (Standard clearances)
-AZ Billet Aluminum Race Girdle for Main Caps
-oil pan (does not come tapped)
1997 USDM ITR B18C5 Head
-Cometic Head gasket
-5 Angle Valve Job
-Deshrouded Valve Ports
-Mild Port/Polish
-Supertech Valves (.05 oversized): Nitride Coated Intake Valves, Iconel Exhaust Valves
-Buddyclub Dual Springs
-KMS Titanium Retainers
-KMS Valve Seals
-Stock ITR Cams
-Skunk2 Cam Gears
-AEBS Billet Aluminum Cam Seal
-New A2 S/S Socket set screws and serrated flange nuts for Exhaust/Turbo Manifold
*$800- Driveshaft Shop DSS Level 5 Axles and Hubs w/ New lower ball joints and New bearings (Passenger hub may need replacing)
*Intercooler SOLD
*Turbo Manifold & Downpipe SOLD
*$800- Garrett GT3582R Turbo w/ .63 AR Exhaust Housing
*$250- Brand new Synapse Synchronic Universal 44mm V-band flange with 50mm valve Wastegate in Black w/ Flanges and Clamps
*$150-1000cc MSD Injectors (Resistor Box required)
*$1100- Brand new Clutch Masters FX700 Twin Clutch Kit (Installed but never used) comes with OEM flywheel bolts torqued down once
See link: http://www.maperformance.com/clutch-...8-913-td7.html
*Coilovers SOLD
*Welds SOLD
*Tires SOLD
*Kirkey Seat SOLD
*$180- Momo Champion Steering Wheel 350mm w/ Momo hub (Excellent Condition and complete with horn button and rings)
*Radiator SOLD
*Fuel Cell SOLD
*$80- Brand new Hawk Performance HB245N631 HP Plus Brake Pad Set w/ OEM DC Calipers
*MSD SOLD
*Camber kit SOLD
*Shift Linkage SOLD
Call or text
424 731 2162 JR
310 961 7175 Rod
*Chassis: $2500
-Custom Rollcage
-Wheelie Bar
-Fresh Paint Job
2-stage (outside)
-AEBS Main studs
-ARP Head studs
-5 Angle Valve Job
-Mild Port/Polish
-KMS Valve Seals
-Stock ITR Cams
-Skunk2 Cam Gears
*Intercooler SOLD
*Coilovers SOLD
*Welds SOLD
*Tires SOLD
*Kirkey Seat SOLD
*Radiator SOLD
*Fuel Cell SOLD
*MSD SOLD
*Camber kit SOLD
*Shift Linkage SOLD
