Introducing Hondata S300 Version 3 and new Ios and Android app!
New features for Version 3:
Ethanol content sensor support
Bluetooth for laptop programming/datalogging and mobile datalogging
2-4 times faster datalogging
CAN output
Serial output for dashboards like the AiM MXL and Racepak IQ3 - (needs 230-vmefi-hond)
Hondata Mobile
Hondata Mobile is an App for iOS and Android, which connects your mobile device to your Bluetooth enabled FlashPro or white board S300 V3. The powerful, yet easy to use design of Hondata Mobile enables instant insights anytime into engine operation from your mobile device, from checking and clearing engine codes to monitoring engine sensors.
Hondata Mobile is a standout product in the Honda Tuning market. Designed specifically for Hondata tuning products, Hondata Mobile is an elegant solution for the customer who demands the best in function, ease of use and well-thought-out design.
Quickly check and clear error codes
Display important engine operating conditions
Custom digital displays and analog gauges
Programmable Shift Light
More details can be found on: http://hondata.com/s300.html and http://hondata.com/mobile.html
You can order directly from your Authorized Hondata Dealer: http://phearable.net/
Oh wow I want the Mobile App, just to be able to monitor without plugging in the laptop. Let me guess, no way to make this work with Version 2?
Yes, it can go up to 4 hours now. Read up on this link:
http://www.hondata.com/s300.html
PS - Whoops, MTBER already posted that, oh well.
Hondata's website says its a "plug in module". Does that mean its user installable? I have a socketed ecu from Phearable and am curious if it's "plug in" in that manner.
it a plug in model for the people who already have the older version, and not it not going to accept a socketed ecu that was meant for eprom chip as I'm assuming you have, but every hondata does come with a kit that need to be solder in to accept the board.
Thanks for the clarification Frost!
I have a spare p28 chipped ecu can I just buy the new s300 and install it on my existing ecu without any further modification?
yes you can but without modification no! your going to have to carefully desolder the chip you have then solder in the new part that come in the kit to accept the hondata board.
Is hondata gonna offer a upgrade to the V3. I have a V1 and was hoping I would be able to upgrade to the V3.
Why not sell the v1 for $350 and save $100.
BTW the Hondata app is not available yet for iOS.
Just saw the links. Thank you!!!http://hondata.com/s300v3upgrade.html
hi i want to get a hondata s300 and been researching about these program for a while. this is a newer version.
will this still be the same program when tuning like the calibrations maps etc? and im reading the hondata S300 guide. will the instructions on tuning program be the same? whats the main difference between the older v2 version? will i be still able to hook it up with a laptop and run my car while tuning? can i tune the hondata s300 with a Mac book pro computer. and lastly if i have a older hondata S300 v2 map already tuned like say from a friend can i upload it to the new hondata S300 v3 and use that set of map? or like lets say base maps from the older version.
please let me know
please let me know
You should really read the links. V3 basically just has Bluetooth and a few other features added. It's not much different than V2 as a whole. According to Hondata the only thing that doesn't transfer over is the wideband tables. You really should read more on this subject.
ive read about fuel ignition tables etc. is it the wide band tables to hook up such as a wideband o2 sensor? can i use my AEM digital air fuel ratio sensor?? would the base map be still reusable transferred from the version 2 base map?
my friend has a couple of tuned base maps of previous tuned motors i bought from him. and want to transfer the current base map version 2 to the version 3 hondata s300 if i would get a set for my p28? is that possible???
sorry for the questions im in need of a ecu soon..
pls let me know i was supposed to buy the v2 but now i just found out u guys made the v3??
