New distributor cap question!
Old Mar 28, 2014 | 09:58 AM
curiousgeorge96's Avatar
Icon3 New distributor cap question!
Real quick guys. I was thinking of buying this distributor cap and coil for my 2002 honda accord ex,
Amazon.com: MSD Ignition 82921 Pro-Cap Modified Distributor Cap: Automotive Amazon.com: MSD Ignition 82921 Pro-Cap Modified Distributor Cap: Automotive
. Just wanted to if i would need a new distributor cap grommet/O ring and if so can someone link me to the part because I have not been able to find it. Thanks!
Old Mar 28, 2014 | 10:05 AM
JuggerNaut-CTR's Avatar
Default Re: New distributor cap question!
Did you know a basic replacement dist cap is like $8?
That is ridiculous waste of money for something that is going to do absolutely nothing for the motor. You literally will not notice a difference at all.
Specific reason behind you wanted to get that?
Old Mar 28, 2014 | 10:30 AM
I was under the impression that it would make a difference in performance. I'm 17 and just starting out in my endeavor to learn about cars and DIY. well then if there is no performance difference then i will get a different cap but what about the O ring im talking about. would you recommend replacing that?
Old Mar 28, 2014 | 12:47 PM
Im just curious what you read or thought you would benefit by installing that on a stock motor? The stock ignition system on honda's is good for quadrouple or more the stock hp.
If it's the inner o-ring you are talking about....then yes, might as well replace it.
Old Mar 28, 2014 | 04:10 PM
MAD_MIKE's Avatar
MM Gruppe B
The factory ignition system is more than adequate for the stock engine.
Only when you have made drastic changes to the engine will you need to do any changes to the ignition system.
Old Mar 30, 2014 | 03:47 PM
My friend told me that he replaces his distributor cap when he does a tune up and says that if you use a performance one that it will put more pep in the step of your car.
Old Mar 30, 2014 | 04:02 PM
holmesnmanny's Avatar
do whatever you think is best then ... really no point asking for advice if you're not going to use it
Old Mar 31, 2014 | 03:03 PM
elinders's Avatar
Try RockAuto.com. They have pretty good prices.
jwarren1904
Jan 16, 2014 11:05 PM
joncowden
Mar 11, 2008 06:14 AM
GRM Scott
Mar 1, 2002 04:41 PM
