How do I unpin my dizzy harness ?
Old Mar 27, 2014 | 09:43 AM
$MIKE$'s Avatar
Default How do I unpin my dizzy harness ?
Ok I am preparing to install my hondata coil on plug and I need to unpin some of the dizzy wires to connect the cpr harness.
I tried to google how to unpin the dizzy wires no luck,
There is no holes like on a regular if I have encountered before
Thanks if you can help I'm sure it's easy..
Here a pic
Old Mar 27, 2014 | 10:09 AM
$MIKE$'s Avatar
Default Re: How do I unpin my dizzy harness ?
Old Mar 27, 2014 | 11:03 AM
1158's Avatar
Did you post this question on Hondata forum too? I saw the answer from Spunkster but my plug is like yours. I don't see the white lock he was talking about.
I'm setting up spare distributor for CPR once I figure out why the car continues to occasionally stumble at part throttle.
Where did you mount the CPR control box?
Good luck!
Old Mar 27, 2014 | 11:31 AM
n/a2boost's Avatar
With neddle nose pliers pull the blue piece out of the plug,then with a small flathead watch screw driver lift the tab holding the pin and pull the wire out. The wire/pin will pull out easy if you lift the tab high enough so do pull to hard.
Old Mar 27, 2014 | 11:43 AM
$MIKE$'s Avatar
Yes I posted in hondata forum and there is no whit lock,
I will give it to hondata they have pretty good customer service.
@na2boos thank you brotha I have not tried it yet but this was the info I was looking for.
I am thinking of doing a Dyi cpr once I get my coils.
Thanks all
Old Mar 27, 2014 | 12:10 PM
1158's Avatar
Thanks all
I just got the lock out. It is so easy you'll be like uh lol. Don't worry about pulling the light blue lock all the way out. There are clips holding the pins in that you will need to lift up then pull the wire out.
Good luck!
Old Mar 27, 2014 | 01:21 PM
$MIKE$'s Avatar
Ok thanks hoping to get my coils tomorrow so I can complete install and finally get tunned
Old Mar 27, 2014 | 03:17 PM
$MIKE$'s Avatar
Got it thanks guys I got it now too easy
Now any good spots to pass it though the fire wall
Old Mar 27, 2014 | 06:54 PM
1158's Avatar
You take the lead on this one lol!
I wish Hondata had made the plug small enough to pass through the pass side firewall hole instead of making it flat and wide.
I don't want to cut a hole but this would be an option: http://www.sealsit.com/firewall.asp
Old Mar 27, 2014 | 07:55 PM
$MIKE$'s Avatar
nice
$MIKE$
Mar 24, 2014 08:32 PM
B18B1-Crx
Dec 21, 2011 01:08 PM
MJT805
Jun 8, 2009 01:41 PM
Steve91
May 31, 2005 05:44 PM
turbotime.
Jun 6, 2003 01:34 PM
