Headstud noob question
Old Mar 27, 2014 | 09:42 AM
austinwasthere's Avatar
Default Headstud noob question
Hello I currently have ls/vtec headstuds but my ls block cracked a sleeve and I'm putting a b16 block in it. I have a b16 head. My friend told me I can use the same headstuds but I was wondering if I need b16 headstuds or I can reuse mine? Thanks a lot
Old Mar 27, 2014 | 07:31 PM
b20vteg757's Avatar
Do you have stock or arp headstuds?
Old Mar 27, 2014 | 07:35 PM
b20vteg757's Avatar
When installing clean the hell out of surfaces before torquing the head down and make sure torque in sequence in steps. I torque to 10, 25, 55, then 75-80 ft lbs and then wait an hour and retorque to 75-80 and then wait another 10 min and check torque again.
Triple, quadruple and then check torque again. Very important to get a good seal. Also I would get the head milled before reinstallation. My local shop does a mill for $50 and that will ensure the head isnt warped.
Old Mar 29, 2014 | 03:46 PM
hybridmiklo's Avatar
Default Re: Headstud noob question
no you cant!!! the head studs are different than the ones used for lsvtec and one for b16!! Its alway s recommended to check warpage of the block and the head before installing with a straight edge.
Old Apr 1, 2014 | 07:30 AM
1320london's Avatar
i 2nd on getting the head checked even if its warped very very little it will not seal for the money its better safe than sorry
Old Apr 2, 2014 | 06:21 AM
CleanLikeJdm's Avatar
Hype-R Stalker
How so? Saying they are doesn't help, over saying how they are different.
I'm pretty sure it varies from vtec/nonvtec heads, blocks make no difference.
Two studs/bolts should be longer for the middle on the LS head.
Old Apr 2, 2014 | 06:32 AM
kyden's Avatar
the b18c headstuds are longer than the b16.
cjbaggs
Oct 4, 2013 12:26 PM
flushsi
Jun 29, 2011 09:37 AM
walker93
Apr 29, 2009 02:06 PM
gd99em1
May 14, 2007 07:08 AM
ScottEK
Dec 11, 2004 01:12 PM
