place vs. hasport
I have used 2 sets of hasport mounts of 2 of my swaps. I am doing a 3rd now and am thinking about using place mounts. HASport is great, but the price is too high, i get get a cheap set of place ones.
question is, is place a good mount?
I have both mount kits. And neither has given me problems. But the Hasport kit does hve two great advantages over Place Racing. One is ground clearance. Now ground clearance is a problem with ANY B-swap. But the Hasport kit gives you a little more. The second is the use of a header. With the Hasport kit, you can use a 4-2-1 header without any problems. But you have to either use a different crossmember or modify the crossmember to fit a 4-2-1 header with the Place Racing kit.
i agree i have an obx 4-2-1 only because it was cheap, but i have b16 head on gsr block and it rubbed on my hood so i had to cut the reinforcements out....
dont get me wrong tho i still love these mounts
ALMOST FORGOT... when i pulled out my motor and changed out my fu**ed up block from HMO
i ripped the rear motor mount insert because i pulled it out by myself and unbolted the rear motor mount but forgot to take it off before i pulled the motor out. but anyways HASPORT fixed the mount for free i just had to pay 5 bucks for shipping.... THAT CUSTOMER SERVICE WAS AWESOME... I sent the mount out on friday got it back the following thurs.
HASPORT
i ripped the rear motor mount insert because i pulled it out by myself and unbolted the rear motor mount but forgot to take it off before i pulled the motor out. but anyways HASPORT fixed the mount for free i just had to pay 5 bucks for shipping.... THAT CUSTOMER SERVICE WAS AWESOME... I sent the mount out on friday got it back the following thurs.HASPORT
I have done over 20 EF + Bseries swaps with different mount kits. Comparing place and Hasport is not even a comparison. If you are not wanting to spend the money on the Hasport mount kit, then get the HCP mounts. I have installed about 12 HCP kits and they are alot better than the place mounts. I would get the Hasport first, but if you are tight on cash, get the HCP.
i don't like how my motor feels like it is trying to shake its way out of my engine bay starting slowly out of first, wondering if this is a soft mount problem (hcp) or just common? a friend with place mounts in an ls vtec crx seems far more stiff, and they are the first generation place mounts, the ones that supposedly had problems.
HCP + 325 shipped = GREAT!!! i have these mounts and they are excelent...go to http://www.jdmshit.com if you have any questions about em ask me!!! i also heard good things about place...i dont think you would have a problem with any of these mounts IMHO
[Modified by RaceFacer, 9:25 PM 10/30/2002]
**** i paied 350 for my hasport. if HCP is 325 (not incl. shipping) and the hasport was 350 including shipping, guess what i will get.... i did a set of HCP and i really thought they were inferior to the hasport setup, from no bolts coming with them, to the HUGE holes that allow for alot of play on the trans mount.
Incubus- you have the Place Racing motor mounts. I have the place mounts in my rex, and they are blue w/ the rubber bushings that say "place racing" on them if you look closely. I love my place racing mounts never had a problem w/ them...knock on wood. I just wish that i would have bashed in the rear crossmember...or whatever that is called by the rear mount..so that it would reduce vibration.
I've wondered about these AZ Racing mounts myself. Something like $230 shipped? Are they made of paper and glue or something? I mean that's cheap, and I'm sure they're ok, but I'm waiting to hear from someone before I get a set. I've been considering making my own but nobody will give me measurements. I'd be willing to make a set for someone that just gave me some measurements. I have a full machine shop here but I can't take the time to bend-n-try-n-bend-n-try.
i have hcp mounts and they work fine but it really sucks that they didnt come with bolts....i had to use a bunch of washers and ****...i would probably buy hasport if i could do it over again...just so i could get the right bolts...only if the hasport mounts were competetivly priced..
