B18C motor, EM1 trans w/ ITR LSD swap ek
I have a 98 JDM GSR with EM1 trans w/ LSD swap. The motor has RS machine 82mm type R pistons and blox 1st gen manifold. Compression tested 180 across with 7 cranks.
The motor will need some work done to it. The valves look toasted but still ran and idle perfect. Burns about a half quart to a quart of oil every 1k miles. Some screw holes on the block and head need to be fixed which include the holes for the half shaft and 2 for the headers.
For the transmission, it is comprised of dc4 trans housing, em1 gears, and usdm itr lsd differential. All the gears shift fine except for reverse. It would grind going into reverse except for when I shift from 1st to reverse.
This swap will include axles, obd2a jdm itr ecu, obd2 distributor, post mount, t-bracket, and AC bracket for ek, ek engine harness, rmf replica headers, shift linkage and a bunch of bolts.
This is a complete swap into any ek.
The motor should have about 50k miles
Im looking for 1450 for everything. text me at 626-500-9958
OMG... Where the hell was this 3 weeks AGO!!!! Ughhh I spent way more than that piecing my swap together AND I'm not even finished.
kaliboy562
Mar 16, 2011 11:25 AM
