1994 Civic EX--headlight/climate power issues
Old Mar 25, 2014 | 02:31 PM
dricha18's Avatar
Icon6 1994 Civic EX--headlight/climate power issues
Just purchased a "new" 1994 Civic EX, 2dr, manual. AS-IS at auction. Drives great. A lot of aftermarket additions that worry me a little (spark plugs, ignition system, intake, alarm system). The stereo was removed rather abruptly.
Have (1) fairly major elec issue...originally, had to turn the headlights on for the climate control to work. Suddenly, neither work (lights or climate control). Background lights still work. Nothing else seems to be out. Assume that there's a short or loose connection somewhere. Started with grounds and fuses-so far cant find a problem. A lot of loose wiring (dead end wires / some burned) under the driver dash and engine compartment. Going through elec schematic to see what does what. Any input to the troubleshooting process would be greatly appreciated!
Dean in central Illinois
Old Mar 25, 2014 | 07:57 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 1994 Civic EX--headlight/climate power issues
Hmmm sounds like a lot of wiring work. Might just grab yourself the Helms manual and go to the junk yard and start pulling cabin wire harness'. Then just straight replace them. Less hassle than rebuilding a harness if it's been badly mutilated. With a replacement harness it's pretty much plug and play.
Old Mar 27, 2014 | 02:21 PM
Swanky_things's Avatar
you said the stereo seems to be abruptly pulled out
and wires that end in random places...
trace back all the wiring to its original harness there should only be two harnesses or so under your dash at that point see what goes to your radio harness isolate all the wiring that comes from individual harnesses with different color tape
ex: all the dead end wires that come from one harness mark it blue tape
all the dead end wires that come from another harness mark it with tan tape
then trace the harnesses to the particular they seem to perform
ex. one harness goes into your steering column
another might go to your ecu
check the head lamps slightly pull back the covering to see if it is for an ex a white wire with orange dashes on it then on your passenger side above the floor board under the dash where the wires go into the cabin locate the same collored wire trace it to where it goes ecu fuse box etc. check where it has been manipulated for aftermarket radio alarm install etc... return it to its original state and its should be just fine...
sounds like a basic wiring issue ... just trace your wires completely through visioaly and physily your bound to find your problem
Old Mar 27, 2014 | 04:44 PM
Former User's Avatar
The climate control lights should only turn on with the light switch on.
Old Apr 1, 2014 | 04:28 PM
dricha18's Avatar
Thank you for all the info...I had hit a dead end and have a lot of avenues to try now.
Enjoying the troubleshooting if you can believe that.
MMMGIRL
Nov 21, 2015 11:39 PM
Moms 94
Nov 2, 2013 08:12 AM
jae401
May 13, 2013 09:14 PM
lived dreams
Jun 30, 2009 01:08 PM
bobjohnson
Apr 20, 2008 06:32 AM
