Spring cleaning sale. eg dc ek em2 oem parts
Hello everyone. I have a few parts I need to sell since they are just collecting dust and taking up space. I am reasonably negotiable since I want to clean up but please don’t over do it. I live in Los Angeles so pick up will be in los Angeles near downtown unless we agree to other terms. sorry if pics are huge.
text/call (323)seven twelve-29-seventy seven. if I don't answer leave message or text since I might be in class or work. thank you
1996 Honda Del Sol Si obdII D16Y8 vtec 5 speed engine harness 8/10 $90
-came off a 96 y8 swap I purchased , I installed the motor on my obd1 hatch so have no need for it. Oxygen sensor plug is broken but only the outer plastic shell not the entire plug besides that the harness is flawless (note: this is like the obd1 harness that plugs in through the shock tower area but is still obd2)
1996 Honda Del Sol Si obdII OEM alternator 8/10 $25
-used my obd1 alternator since I was using an obd1 engine harness , was working perfectly fine before motor was taken out of the del sol.
1993 Honda Civic ex cluster (351377 miles) 5/10 $15
-bought this on ebay to only use the fuel/temp gauge on my ex cluster, never tested the other gauges since I didn’t need them but the fuel/temp works perfect so I assume it works as stated on the ebay listing.
92-95 Civic eg corner lights -sold
92-95 Keyless door handles off eg sedan 8/10 $old
-was going to use them to delete keyholes on my hatch but never got around to installing the keyless entry. Original black molding finish.
92-95 Civic Blox LCAs no bushings 6/10
originally red but sprayed silver to match subframe brace I use to own. Paint is chipping still in good condition, bushings are estimated at around 20 bucks at auto parts store.
92-95 Civic 3dr quarter panel speaker covers 8/10 $old
-each has a scratch or two nothing major still looks clean no broken tabs , I kept the cleaner set and I rather get rid of them before they get even more damaged from being in storage.
01-05 em2 Civic AEM intake with carb stickers 6/10 -sold
96 Acura integra Rear brake calipers 5/10 $40
Driver side- needs a rebuild because ebrake part sticks
Passenger side – is good but can prolly use a rebuild soon too since they originally came together.
99-00 Raybrig foglight w/ cracked clear lense and missing back bulb cover 5/10 $15
Eg/dc Momo hub with rubber cover part # c4911 8/10 $50
B7 intake manifold complete 7/10 SOLD
It has throttle body/ throttle cable/fuel rail/fpr/iacv but needs the tb gasket and needs new tps. All sensors/tb are loose
96 obd2 del sol si engine harness
96 obd2 alternator
92-95 keyless doorhandles
Blox lcas
Eg hatch rear speaker covers
Ac
Cluster
Foglight
96 obd2 alternator
Blox lcas
Ac
Cluster
Foglight
Eg5ir1
Jul 20, 2013 06:58 PM
Eg5ir1
Jun 17, 2013 07:24 PM
