Erratic idle....jumps up and down around 650-850.
Old Oct 29, 2002 | 04:15 PM
freeplay's Avatar
Default Erratic idle....jumps up and down around 650-850.
When I let the gas off and my car's idling...it stays around 750rpm. Then a few seconds later, it starts bouncing around. I have the hack and 450's. settings are on -35% across the board. Yes...I've tried different %'s. Any ideas? Thanks
Old Oct 29, 2002 | 06:02 PM
horror's Avatar
Default Re: Erratic idle....jumps up and down around 650-850. (BoostInBoi)
check your vaccuum lines for a leak...that happened to me a couple weeks ago, and that was the problem
Old Oct 29, 2002 | 06:04 PM
freeplay's Avatar
Default Re: Erratic idle....jumps up and down around 650-850. (poxu)
hmmmm.......i will try that. any other suggestions? thanks
Old Oct 29, 2002 | 06:42 PM
sutrusu's Avatar
bump for you.. i want to find out as well.
Old Oct 29, 2002 | 07:53 PM
CzanSOHC's Avatar
Default Re: Erratic idle....jumps up and down around 650-850. (sutrusu)
yep, prolly leaking around the where the injectors fit into the intake manifold.
BlueByYou
Mar 14, 2013 07:19 PM
SkoundrelUSA
Sep 2, 2006 07:32 PM
CRAZYHONDA
Mar 29, 2005 10:17 PM
4_door_teg
Oct 25, 2004 05:18 PM
CRX Si
Mar 11, 2003 03:50 PM
