99 EM1 Wheel Bearing Question.
Old Mar 24, 2014 | 02:34 PM
jason_SIR's Avatar
Default 99 EM1 Wheel Bearing Question.
i Have a 99 em1 and need to replace a wheel bearing was just woundering if i really need to replace with the ABS bearings as the cost is much higher as aposed to the non abs wheel bearings.
Old Mar 24, 2014 | 02:51 PM
Brewbot87's Avatar
Default Re: 99 EM1 Wheel Bearing Question.
If your car has abs, then yes you do need the abs bearing. The one side has a magnetic ring that the sensor reads so make sure that side faces in. Use a paper clip or something to identify which side is magnetic. But I don't think em1s have abs. I could be wrong about that.
Old Mar 24, 2014 | 05:06 PM
Hugh_Jorgens's Avatar
USDM EM1s have no ABS. I think candian models did, though. If your car has ABS, you need an ABS bearing. Check on rockauto if you're buying an aftermarket bearing.
Old Mar 24, 2014 | 05:59 PM
Mad-Mike's Avatar
Just a tip don't use driveworks wheel bearings. I had one on my EG and it lasted about 6 months(Chinese junk). Go with Timkins.
Old Mar 24, 2014 | 07:07 PM
Yes, Timken is a very good aftermarket replacement brand. I believe they are still made in Japan.
Old Mar 24, 2014 | 07:25 PM
tony_2018's Avatar
Fish Twig
wtf...............
Old Mar 24, 2014 | 07:26 PM
tony_2018's Avatar
Fish Twig
Whats funny is I bought a timken bearing only to find out it was a koyo bearing. How bad *** was that.
Old Mar 25, 2014 | 05:22 AM
94CivicSi's Avatar
I also just received a bearing yesterday in Timken box, but it was stamped Koyo.
Unfortunately, I paid more because I thought was getting the Timken. I could have gotten the Koyo for ~$20 less. Debating whether or not to make an issue out of it.
Am I misinformed that NTN or Timken is the OEM equivalent? Majestic sells NTN @ ~$88. This Timken I purchased was originally $86, on sale for $61 shipped though. Found Koyos all day for $40 shipped.
Old Mar 25, 2014 | 10:04 AM
tony_2018's Avatar
Fish Twig
You live, you learn. I've made purchasing mistakes before but its because I was in a rush. Sometimes when I order from online oem dealers I look for the cheapest price AFTER shipping is included. Every single one of them have there hits or miss plus it also depends on who is located closer to your location for cheaper shipping.
Old Mar 25, 2014 | 01:49 PM
Brewbot87's Avatar
wtf...............
travisr138
Suspension & Brakes
Jan 25, 2009 06:57 PM
youdontknowmeeither
Dec 20, 2006 08:50 PM
wrx'n you
Aug 28, 2006 09:38 AM
alexdog69
Oct 18, 2004 02:43 AM
