Is it a fuse?!
Old Mar 24, 2014 | 12:34 AM
thomaswjparker's Avatar
Icon2 Is it a fuse?!
Hi there,
Recently my mate and I tried to put a head unit in my 1990 honda civic, and unfortunately we think we may have blown a fuse.. But not too sure, hence why I am here!
The clock, cigarette lighter, internal light and the power to the radio won't work. Does anybody know how to help me out here? Is it the fuse, or something bigger? And if it is the fuse, does anyone know which one it is?
Needing help, as going on a road trip soon so have to get these sounds in my car!
Cheers,
Thomas
Old Mar 24, 2014 | 06:01 AM
Glowicki's Avatar
Your fuse box is behind a removal panel on the driver side under the dash. The back of the panel has a diagram of which fuse goes to what. Pull the fuse and hold it up to the light. If it looks melted or burnt in the middle, it's toast. Replace the bad fuse with another good fuse if the same amperage.
If you keep blowing the same fuse, you'll have to figure out why it keeps blowing and fix that issue.
Old Mar 24, 2014 | 06:58 AM
KevinEF7's Avatar
Default Re: Is it a fuse?!
You dont need to pull the fuses out of there slots, each fuse has 2 metal squares on its top you can probe with a multimeter (meter set to continuity). Touch both squares of each fuse, if the meter beeps, fuse is good, doesnt beep, fuse is bad
Sounds like a fuse for sure though
Old Mar 24, 2014 | 06:59 AM
jlicrx's Avatar
fuse number 12 - last one on right in bottom row
NACvicSi
Aug 27, 2009 05:03 PM
Hanmin
May 16, 2008 02:17 AM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
