95 Accord EX Station Wagon wont start after new plugs and wires
Well I replaced the spark plugs and wires on my 95 accord and now it won't start. It ran fine before but now, all it does is turn over. Wires are correct. There is spark. Fuel pressure is where it should be. New battery. New distributor. What could cause this? Any suggestions?
Doubly doubly make sure you didnt hook them up wrong. If there from autozone, those are crap, could be a bad set of wires.
They are connected right. And they are the the Duralast ones from autozone. I've never had a problem with eurozone wires before. Are you sure that could be the case?
Am I sure that could be the case? Of course I am sure it "COULD" be the case
I have bought more than one set, from autozone that were poorly built. If it ran right before, then doesnt run right after... Return them and get a new set, see if that fixes it.
Well when i got home from work yesterday I thought "Wonder if itll start now. Lets give it a shot." So I tried starting it. It turned over the first time and ran for about 3-4sec then immediately shut off. It did this for the next 5 times I tried starting it. Any idea why its doing this?
My guess is ignition switch.
When you replaced the wires, did you replace them one at at time, or did you go by a diagram in a Chiltons manual(which is wrong)?
Crank engine so that the rotor is pointing to #1tower on the distributor, sometimes marked with a A or A1. Make sure it is on #1 spark plug which is the plug closest to the timing belt. Then check the firing order 1-3-4-2.
Could you explain what they got wrong about spark plug replacement in the Chilton manual, and possibly any other things you know they got wrong as well?
flymedic37
13
Jun 30, 2013 06:33 PM
micah13x
11
Apr 14, 2011 03:09 PM
