92 Civic hatch/jdm b16 - what 4-2-1 header has clearance for radiator/condenser
Old Mar 23, 2014 | 05:19 PM
jasmin92993's Avatar
Default 92 Civic hatch/jdm b16 - what 4-2-1 header has clearance for radiator/condenser
I have a 1992 honda civic hatchback with a jdm b16. I have my stock radiator and fan, and ac lines and condenser. Im looking for a 4-2-1 header that has the clearance for the radiator and condenser.
Old Mar 23, 2014 | 08:31 PM
Hugh_Jorgens's Avatar
Default Re: b16 header
Th the best *commonly available* headers I've seen are the PLM RMF narrow rep and the Toda or PLM Toda rep.
The Toda/rep clears everything as is. Makes good midrange...but really shines up on the top end.
The RMF is more of a 4-1. It makes super healthy midrange and good top end. You have to trim the rad fan or use a slim fan.
I personally had the RMF rep on my almost stock 01 ITR (also had intake and high flow 2.5" cat). I trimmed my fan when I had a stock radiator and had 0 issues. I also had to trim a slim fan when I got a fluidyne radiator. Only issue was heat getting into the slave cylinder when I tracked the car hard. A little heat shielding and better fluid would cure it.
My friend put the Toda rep on my EM1 that he bought from me that had a 00 Spec R swap and an Endyn head and worldsport exhaust with test pipe. Maybe the combination of all that is why that car had such good top end.
accord2civic2prelude
Apr 25, 2010 09:55 PM
savedone
Oct 21, 2006 12:39 PM
SLaMmEd GsR
Jun 25, 2005 07:03 AM
NiceDc2r
Jul 9, 2004 03:57 PM
Mike K
Jun 6, 2002 12:09 PM
