95 Del Sol " NO START" II
Can I bypass my ignition switch to manually energize my main fuel pump relay to turn on my fuel pump so I can get the dang car out of my driveway?? I need to run it 60 miles up the road where it can sit until I got the issue under raps.
IF YES, What would be the best way?? Run a switched ground wire to pin 7's wire at the ECU ??? This will turn on the fuel pump for sure.
ANY THOUGHTS ?? Thanks Harley
Its not filled with b.s. if everything was diagnosed properly. If swapping out the main relay isn't the issue than its clearly a wiring issue, as I just stated in your other thread. You will need to check for continuity, check for power when key is on and off, check for ground when key is on and off. Please do so and report back dude.
PetesPonies
Sep 9, 2019 06:36 AM
All Hondagirl
12
Aug 6, 2016 12:52 PM
JeffC
11
Jun 16, 2012 08:56 AM
