Crx headlight issue/HID issue?
Hey guys
I have a crx shell that I installed HID's into and all was working fine the first night but I also did a battery relocation during this time and since the battery relocation has been done the passenger side HID will not turn on?
I have swapped over the known working bulb and ballast from the other side and still same problem. I have also checked the under dash low beam fuses and they are good. I ground down the chassis where the headlight ground goes trying to get a better connection thinking that may be the problem. Still nothing. Also if I put a regular halogen bulb in the stock housing it will work fine? Any thoughts?
sounds like you need a voltmeter to check for good voltage. some electronics will not work at low voltage, but everything else will work correctly.
Regards
Dave
Regards
Dave
OK so I took your advice and checked voltage at the low beam plug even tho the stock halogen bulb works and I came up with 11.6 volts. This is the same power that is coming direct off the battery so that means I'm good there right? What can I check next?
It's got to be a ground and/or wiring issue, I don't think directly related to the battery if one side still works.
Connect the voltmeter + cable to the red cable that's running into the HID module, and ground the black; see what the voltage is, something might of simply come lose.
Matt
Matt
seabassrsx19
Sep 26, 2008 07:00 PM
