93 honda prelude abs take out
im taking out my abs pump but these metal brake lines are getting in the way i tried to take them out and stripped the nut a little bit its a 10mm but it unbelevably hard to turn any tools i can get to help
quite a bit more complicated than just removing the pump, you have to change and alter brake lines, get the correct non-abs prop valve, remove just about everything that controls the abs. sensors, wiring, and the abs box.
scoobyghost
Aug 30, 2004 06:15 PM
