Suspension Techniques springs.... got them in tonight
does 232.80 front and 132.80 for the back sound right? I have the stats here, but there are so many numbers I don't even know?
as far as lowering..... probably about an inch or so. give or take 1/4 inch either way? When my arm gets better I'll post pics of before the springs and after.
someone let me know if those numbers sound right
hows this
at 10.5" 123
at 6.5" 640
for the rears
fronts are
at 11.5" 240
at 8.00" 1065
I don't know how to read this but it goes by .5" increaments
what are the stock itr springs?
[Modified by typer.org, 8:17 PM 10/29/2002]
at 10.5" 123
at 6.5" 640
for the rears
fronts are
at 11.5" 240
at 8.00" 1065
Progressive rate springs front a rear, nice. here are the stock specs.
The front spring is 246, the rear is 140-246.
From what i can tell, you gave the rates under no compression 123 rear, and 240 front. But since they are progressive those numbers change all the time essentially.
once my arm gets better I'll put them on. I might not put them on until winter is over though.
with snow and the salt it would probably be better to put them on after.....
I don't know we'll see
how do I figure out what the spring rates are on these springs?
good luck.
hungsteR
Feb 28, 2006 07:49 PM
HapiHonda
Oct 21, 2002 03:08 PM
ITR0145
Apr 6, 2002 11:00 PM
