Walbro Fuel Pump Problems
Old Mar 23, 2014 | 07:51 AM
dpopoff's Avatar
Default Walbro Fuel Pump Problems
Just installed a Walbro 255 fuel pump into my 94 prelude.I had to use hte old filter on the new pump because the new one would not fit into the gas tank. Took for about a 2 hour drive and right when I pulled into my drive way, steam started to pour out of the engine. It looks like it is coming right from under the distributor. All hoses and frost plugs are still in/attached. When the car is idling, the fuel pump goes on and off.
Old Mar 23, 2014 | 05:19 PM
bamaland601's Avatar
Default Re: Walbro Fuel Pump Problems
its supposed to go on and off.
if theres steam, there has to be a leak, any oil or coolant spots? only things under the dizzy are, heater hose, temp sensor for ecu, and cam sensor.
get hold of an aftermarket temp gauge and hook it to the plug thats on the front top radiator spout.
check fluid levels and conditions
flanker
Oct 2, 2016 11:07 PM
76 camaro car
Sep 23, 2015 02:00 PM
jj07
Jun 9, 2010 12:34 PM
CoolRedXylophone
17
Mar 19, 2006 08:46 AM
StupidSlowRSX
10
May 3, 2004 02:34 PM
